Question about Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
how can i bridge my orion hcca 250 to 1ohm to get 800w
and if i bridge the hcca 250 will it over heat if i will connect
two orion xtreme 500w 12" subs
  • Anonymous Mar 17, 2014
    What is a good amp for 2 10 inch hcca orion subs
    Problem Solver:
  • 7 Answers
I can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Posted on Sep 18, 2009
This amp is stable down to 0.5ohm in stereo (2x400) and 1ohm in mono(1x800).
Posted on Sep 03, 2009
    Problem Solver:
  • 7 Answers
Yup! If you want a amplifier this is the only one to get.(except for the Manhattan 1-nuclear car amp. sells for 250,000 dollars.) that's a cool quarter of a million! I think i'll take the Orion hcca amp any old day. I think the 2.50 also doubles as a welder..lol. jk don't try to weld with it, seriously.
Posted on Jan 21, 2013
  • Scott Yowell
    Scott Yowell Jan 21, 2013
    If this amp is overheating with 4ohms on it...something is definitly wrong. this baby shouldn't get hot until it's seeing 2 ohms at least. and then it might get warm. And besides these suckers are built to get hot...thats why they have hear sinks...
  • 80 Answers
Yes that amp is not made for bridging to 1 ohm it might do it but it will eventually burn out! i check your specs online!
thanks
erik
Posted on Feb 27, 2009
How to bridge a Orion 250 hcca amp?
Should have a diagram on the bottom of amp or where you hook up the speakers to amp......Its usually the two outside speaker connections.....just be sure to hookup negative to negative and positive to positive.let me know if this helps.........
Mar 25, 2012 | Orion Car Audio & Video
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
To make a box for a single hcca 12 inch
3/4 inch partical board 2inch wood screws,make sure that you read the spec size because thats what makes you deep bass.Peace
Oct 30, 2009 | Orion HCCA 12D Car Speaker
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion 250G4
Generally to bridge an amplifier you need to insert the positive wire from the sub to the positive wire on the first channel. And then insert the negative wire from the sub to the second channels's negative terminal.
Apr 22, 2008 | Orion HCCA 225G4 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
934 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
