Question about Electrical Supplies
We are manufacture of diesel enigne and diesel generator
We are manufacture of diesel engine for (15-155kw ) and diesel generating set (8---1000kw) ,we are located in power city ___ weifang city , China .any interested , please contact: Yahoo ID: qlygterry2003
  • 169 Answers
Uh huh, and you shouldn't be posting your advertisement in this part of FixYa.
Carl
Posted on Mar 01, 2009
Have an ex1000 generator it has for gets fuel just won't kick over
Dear, your meaning is 1000KW generator? It fails to start?
If it is, maybe you can get some help from this article. Why Diesel Generator Fail to Start
If you want to inquire diesel generator/silent generator set, kindly visit this website. Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
Any questions, kindly contact me.
Sep 20, 2017 | Electrical Supplies
My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
Jan 12, 2016 | Kipor Electrical Supplies
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
What is a glow plug
Glow plugs are heating devices to aid starting diesel vehicles.
Purpose:Diesel engines, unlike petrol engines, do not use spark plugs to induce combustion. Instead, they rely solely on compression to raise the temperature of the air to a point where the diesel will combust spontaneously when introduced to the hot high pressure air. The high pressure and spray pattern of the diesel ensures a controlled, complete burn. The piston rises, compressing the air in the cylinder; this causes the air's temperature to rise. By the time the piston reaches the top of its travel path, the temperature in the cylinder is very high. The fuel mist is then sprayed into the cylinder; it instantly combusts, forcing the piston downwards, thus generating power. The pressure required to heat the air to that temperature, however, necessitates the use of a large and very strong engine block. The problem posed is that in cold weather, if the engine has not been running (as is the case when the car is left to sit overnight), that the large engine block becomes very cold; when one then attempts to start the engine, the cold engine block acts as a heat sink, quickly dissipating the heat generated by the pistons compressing air. The engine is then unable to start, because it cannot generate and maintain enough heat for the fuel to ignite. For that reason indirect injected diesel engines are manufactured with glow-plugs in each prechamber, and direct injected diesel engines are manufactured with glow-plugs in each combustion chamber.
Wikipedia
Dec 07, 2011 | Cars & Trucks
Can we get a maintenance manual for this generator ?
I would go to the manufacturers website and check your model number. I am a plumber and do this frequently for different pumps and other things. Most of the time you can download and print the manual. Just look for literature or manuals.
Nov 25, 2011 | Multiquip GA6HA Recoil Start 6000 Watt...
I need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
How do I remove the alternator on my 1998 Dodge 1500 4wd?
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO ELECTRICAL SYSTEM .
  1. Disconnect negative battery cable at battery. Diesel Engines: Disconnect both negative battery cables at both batteries.
  2. Remove generator drive belt.
  1. Remove generator pivot and mounting bolts/nut. The diesel engine uses a bolt at top mounting and a bolt/nut at lower mounting. Position generator for access to wire connectors.
  1. Remove nuts from harness holddown, battery terminal, ground terminal and 2 field terminals. Remove wire connectors. A typical generator wiring harness is shown in. Wiring harness routing as shown may be slightly different depending on vehicle model and/or engine.
  2. Remove generator from vehicle.
INSTALLATION
  1. Position generator to engine and install wiring to rear of generator. Tighten all wiring fasteners as follows:
    • Battery terminal nut-8.5 N.m (75 in. lbs.)
    • Ground terminal nut-8.5 N.m (75 in.lbs.)
    • Harness holddown nut-8.5 N.m (75 in. lbs.)
    • Field terminal nuts-2.8 N.m (25 in. lbs.)
  1. Install generator mounting fasteners and tighten as follows:
    • Generator mounting bolt-All gas powered engines-41 N.m (30 ft. lbs.)
    • Generator pivot bolt/nut-All gas powered engines-41 N.m (30 ft. lbs.)
    • Generator mounting bolt-Diesel powered engines-54 N.m (40 ft. lbs.)
    • Generator pivot bolt/nut-Diesel powered engines-54 N.m (40 ft. lbs.)
CAUTION :
  • Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
  • When installing a serpentine accessory drive belt, the belt MUST be routed correctly. The water pump will be rotating in the wrong direction if the belt is installed incorrectly, causing the engine to overheat.
  1. Install generator drive belt.
  2. Install negative battery cable(s) to battery(s).
Dec 13, 2010 | 1998 Dodge Ram 1500 4WD
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Electrical Supplies Logo
186 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
