Question about Toshiba 50H81 50" Rear Projection Television
Replaced stk's but I still can't move the red vertically
What should I look for now. I have an auto focus error message also when auto focus button is pushed.
    Genius:
  • 1,550 Answers
Did you replace both the convergence ICs ?
The auto-focus won't work properly until BOTH Convergence amps are replaced .
Also you need to replace various resistors along with it .
Posted on Feb 25, 2009
On my HD1080 Mitsubishi projection flat screen 55809 the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center....
It could be one of two things: Either a bad solder joint or convergence IC failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 20, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitusbishi ws-a65 hd 1080 tv. im having trouble getting the picture to line up with the shodows, its showing double, how can i fix this?
Your Convergence ICs have likely failed. It is very common on rear projections. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Look for the converge option to align the red and blue colors
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi Televison & Video
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Red out of focus
Hi. your convergence board is failing. this board regulates the the alignment procedure and , the chip set is damaged. replace the convergence board soon.
May 22, 2009 | Toshiba 42H81 42" Rear Projection...
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Help I have a 3 D image
You need to replace 2 ships stk 392-150 any question I'll be glad to help you 401 6170008 my name is George
Jan 19, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
