Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Take Off Sleep Mode
I just bought a Brother MFC-7840W.
I can not get it off sleep mode.
The manual is unclear.
  • adamsts Mar 13, 2009
    My printer printed OK, from all computers on the network , when it was set up.
    Now, none of us can print. The printer icon on the computers ( in the control panel) shows 'offline', and the printer's status is 'sleep'.
    How can we fix this?
    Thanks
    Denise
  • 3 Answers
(same response posted in another thread)
The issue is NOT the sleep mode)/
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
  • Chris Silva
    Chris Silva Apr 20, 2017
    This worked for me ! Thank u
Hi, my printer Brother MFC-9320CW enters in sleep mode every 30minutes. Any cloues how to clear the timing?
try fixing the SLEEP menu.
Follow the steps I found:
Enter Menu and navigate to General Setup. To enter press OK. Use up or down arrow buttons to go to Ecology and again press OK. Enter Sleep Time menu and enter 0 if you don't want your brother to enter sleep mode. Press OK and exit printers menu.
May 06, 2012 | Brother MFC9320CW All-In-One Printer
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    My printer: brother model mfc 215c is not working.
    Brother model MFC-215C is not working. It says: cleaninig impossible. Try trouble shooting and routine maintenanace. What can I do to solve this problem?
    Jul 26, 2010 | Brother MFC 210C All-In-One InkJet Printer
    How to stop sleep mode?
    Sleep Mode
    Setting the Sleep Mode reduces power consumption while the machine is idle.
    You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
    it drops into sleep mode. The timer automatically resets itself after the machine
    receives a fax or PC data or makes a copy. The default setting is 0 minutes.
    1 Press Menu/Set, 1, 7.
    2 Use the Dial pad to enter the length of
    time the machine is idle before it drops into sleep mode (00 to 99 minutes),
    and then press Menu/Set.
    3 Press Stop/Exit.
    Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
    Lcd says sleep 10: 35 fax. What does that mean?
    The machine goes into the sleep mode after the amount of time you set to conserve energy. It is sleeping and will wake if a fax comes in, fax tells you it is in the fax mode and not the manual mode or fax/tel mode. 10:35 is the time of day.
    Oct 13, 2009 | Brother MFC 6800 All-In-One Laser Printer
    Fax machine sleep mode
    have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
    Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
    "Receiving Sleep" on Brother Fax 4100
    you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
    Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
    7,097 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
