Question about GE GSH25JFR Side by Side Refrigerator
Refrigerator cycling on/off and surging
Have a GE GSH25JFRF refrigerator that is cycling on/off and surging. The fan sounds to be reving on/off and there is a sound like wind howling through a hole. Inside is cold.
  • Anonymous Apr 21, 2009
    Compressor is surging occasionally.
    Model is GE GSH25JSFRF
    It is about 3 years old
  • Anonymous May 19, 2009
    Heard surging noises from the ice maker side of the fridge like if the power was sputtering on and off. Not sure if some power supply was giving out or not. This went on for about 20 minutes and disappeared. The ice is frozen and the drinks are cold. Weird.
SolutionGuy
  • 331 Answers
SOURCE: GE SIDE BY SIDE REFRIGERATOR
Kay, these are known for having faulty evaporator fan motors (failed motor bearings). This is what has failed in your fridge. This is a tedious and time consuming repair, you may want to purchase the evap motor and hire someone to install it for you. Just one of the reasons I recommend this is that 50% of the time, the new motor's wiring harness will not match the harness on the fridge and so must be converted to adapt. The evaporator fan motor is the fan inside the freezer, behind the back panels. If you choose to repair it yourself, UNPLUG THE FRIDGE FIRST! Then remove all items from freezer. Remove all shelves and bins. Remove the ice bin. Remove the lower back panel. You should be able to see the motor now, but you can not access it yet. The motor is mounted in a plastic shell/housing, this entire housing must be removed (along with the related wire harness). Install the new motor and rebuild the unit. This doesn't sound like much, but since you've not done one before, figure 2 1/2 to 3 hour job time. (With practice, it still takes us ~50 minutes) Wiring is CRUCIAL! Take note of EVERYTHING and the way things are routed in there. Otherwise, you won't know if you did it right until you have it rebuilt and plugged back in, if something were mis-wired... you'll know it now. Then have to disassemble to locate the problem. The part number you'll need is #WR60X10185, and sells for ~$45.00 at your local appliance parts retailer. If you hire someone to perform the labor, they won't be able to "soak" you on the part price. The good news is that after the repair is complete, your fridge will cool better AND I've never had a callback on these! (Which means that the replacement motors are MUCH better than the original factory installed ones.)
Posted on Aug 11, 2007
SOURCE: Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Posted on Apr 18, 2008
nandini789
  • 430 Answers
SOURCE: GE Model PSC23SGRC SS Serial #RH418861.
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Posted on Sep 07, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator and freezer not getting cold side by side
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 25, 2010
mreid542
  • 166 Answers
SOURCE: GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Posted on Jul 12, 2010
Ge gsh25jfrf bb sise by side refrigerator. Freezer not cold, fan not running, not turning, and is making a clicking sound. What's the cause of this?
if the fan is making a clicking noise, replace it, but be prepaired to replace the main pcb if it does not start right up..... on a ge if the evap fan motor shorts it will take out the mother board (pcb)
Oct 09, 2014 | Refrigerators
Ge gsh jstass
There could be problem with the electronic control board. This controls the fan operation as well as all other operations of the refrigerator.
May 19, 2014 | GE Refrigerators
HAVE A ge FRIDGE SIDE BY SIDE MADE IN MARCH OF 05. GSH25JFRF CC. gETS COLD IF SETTING IS SET ON THE HIGHEST 9, BUT CANNOT PUT ANYTHING IN BOTTOM CRISPER OR IT WILL FREEZE. HELP PLEASE
Hello Karenlovey,
I understand that your are having a problem with your fridge it will only cool when set on the coldest setting. This is a common problem when the fan or the condensation coils are dirty. Here is a tip that you may want to take a look at and follow to see if it corrects the problem.
Fridge not cooling Properly!
Thank you for choosing FixYa.com
Justin
May 11, 2011 | GE GSH25JFR Side by Side Refrigerator
I have a GE GSH25JFRF BB refrigerator that will stop working every 3 to 4 days, i unplug it and plug it back in and it works, also the ice quit despensing about the same time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 15, 2010 | GE GSH25JFR Side by Side Refrigerator
GE GSS25IFRF "surging"
The motherboard (part 801 on diagram) controls the speed of the fans and it may be going bad. The round type of condenser fan you have may be the cause of the weird sound.(part 730) Make sure it's clean. As long as it's cold you can run it just beware it may stop. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5241174&diagram_id=24104631#d24104631
May 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My side by side ge refrigerator model gss20iepjcc make a holling sound. it is caused by the fan motor in the freezer slowing and reving up constantly. what is the solution to this problem?
Normally this fan is silent in operation, and does adjust it's speed dependent on temperature requirements.
However - if it is on all the time, thee may be a fault with either the sensor or temperature control (main) board.
If the sound does actually stop for intervals - just buy a replacement fan, as the bearings may be corroded enough to make it noisy.
You can replace this as a DIY fix if unplugged, and the back panel removed.
Mar 02, 2010 | GE Refrigerators
Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
Fan in Freezer surging??
Replace evap fan motor. Should be a white plastic housing made by Panasonic.
Jul 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
515 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
