Question about Ricoh Aficio 1515 All-In-One Laser Printer
Wast Ink Tank B!!!???
This message in the monitor:
"Wast Ink Tank B : is full. Please call service"
if was find the tank & clean it but the problem is still same message.
So..
please advice
  • 3 more comments
  • khalid_k Feb 26, 2009
    Dear Sir
    You are right; the model for Ricoh Aficio is MP C1500SP.
    & I was found the wast Ink Tank B, & I was clean it, but the problem still same message.
    So..
    Please advice
  • khalid_k Feb 27, 2009
    So..
    Please advice
  • khalid_k Mar 03, 2009
    The model for Ricoh Aficio is MP C1500SP.
    So please advice
    sandmanmac
  • khalid_k Mar 04, 2009
    sandmanmac
    Thanks i will try & we will see!
  • Anonymous May 11, 2010
    I think you've got the wrong model...there is no waste tank on a Ricoh Aficio 1515
Sorry don't know that model here...:(
Posted on Feb 27, 2009
  • Anonymous Mar 03, 2009
    That model not available over here, so I don't know for sure, but is the bottle a fairly simple 'clear" style?
    If so, then try this (only if it is as I stated), put a few spoonfuls of sugar into the bottle, shake it around and dump it out.
    What is probably happening is that the machine is still 'seeing' toner via a sensor, due to the left over residue within the bottle.
    I know it may sound like a silly solution, but the toner sticks very well to the sugar.
    Again, only use this procedure if the bottle is simply that.....a fairly clear, simple style.....good luck
Reset wate tank ricoh sg2100n
there is no way to reset it.
you need buy a new one.
May 19, 2014 | Office Equipment & Supplies
Wast Ink is Over Flowing
the waste ink tank is full.remove the unit and clean the old ink out and clean sponges.
Oct 26, 2012 | HP OfficeJet Pro k550 Printer
The ink absorber is full
plese it is problem your printer is not print because some of ink is full printer wast tank clean it and reset press printer resum button two times
if you are not success then you go to in your area service authorised delar
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
When i try to print i get an error msg saying waste ink reserve tank is full
the waste ink reserv tank is under where the cartridge sits when not in use. if you send it ti be serviced they clean it out, however if you any good at taking pieces apart you can get a good wad of tissue and scoop it out your self, just make sure you clean where the sensor is and it will carry on. if you use a solvent to clean it up sparkly be care full not to get it in any boards or circutry oh! and turn it of the power first
Aug 27, 2009 | Canon Pixma MP450 All-In-One InkJet...
(E 27)
yes your printer wast ink is full. You go to aser canon service center thay reset your printer then omet this signal and active to print
Jul 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Ricoh Aficio 1515 All-In-One Laser Printer Logo
202 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
