Question about Samsung Televison & Video
I HAVE A SAMSUNG 74CM TV.IT IS FLASHING ORANGE ON THE STANBY LIGHT
I have a Curtis Mathes Model CM27101S that has a Parental Control block. How can I unblock it?
Posted on Feb 25, 2009
  • Jonathan Yelverton Feb 25, 2009
    I have a Curtis Mathes TV model CM27101S that has a Parental control block. How can I unblock it?
How to watch 3D movies
Use a 3D spectacle to feel it better.
Jan 08, 2017 | Samsung Televison & Video
MY SAMSUNG TV IS ONLY SHOWING A BLACK SCREEN WHEN IT POWERS ON THE MODEL NUBER IS UN60EH6002FXZA WHAT DO U THINK IS WRONG WITH IT
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Jan 07, 2017 | Samsung Televison & Video
I can't watch a movie from my Samsung DVD player it is hooked up to Bose and tv
Unless your dvd player is defective you have it wired incorrectly. Have someone else check what you did.
Tv will not turn on, orange light flashing
Could be an open internal fuse or power supply failure
Jan 07, 2017 | Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
No Video Or Sound - Stand By Light Flashes 5 Times
If the tv was made before December 2008, there is a capacitor settlement from a class action lawsuit by Samsung. Supposedly (at no charge) they will send a repairman to replace the capacitors.
Nov 27, 2013 | Televison & Video
Samsung DLP HLS4266W
Check the fittings of the color wheel. Refer this site for more details.
May 17, 2013 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
