Question about Walkera Dragonfly #68 7 Channel 3D Aerobatic Radio Remote Controlled Electric Rc Helicopter Ready To Fly
Walkera 37 remote heli
Walkera 37 helicopter the moter seems to turn clockwise instead of anticlockwise can anyone help me this is the 2nd one i have purchesd the moter is a 380sd brushed moter thanks
  • 68 Answers
Swap over the two wires that go from the motor to the speed controller. NB. don't swap over the wires at the battery this will destroy the speed controller.
Posted on Aug 31, 2009
5 Suggested Answers
  • 6 Answers
SOURCE: heli max hicro helicopter just keeps spinning in circles
Make sure you used the right blades, the top and bottom blades are different parts and if you try to replace an upper blade with a lower blade it will mess up the flight. The two sets of blades are reversed, the leading edge is on the opposite side because they spin in opposite directions.
If you are sure you have the correct blades, try to eliminate vibrations, especially in the upper rotor. Vibrations can throw off the gyro sensor and cause the helicopter to spin. If it isn't vibrating then you need to adjust the trim. If it is just a slight spin, you can try using the horizontal trim adjustment on the left stick. If this is not able to correct the spin, set the horizontal trim on the left stick to center and then remove the plastic canopy. On the circuit board you will see two screw adjustments labeled "SENS" and "SCALE". First, draw a mark on both of them with a marker making sure to touch both the screw and the plastic or board. This mark will be used to reset the knobs to their original positions if you mess up. The "SENS" (sensitivity) knob adjusts how hard the helicopter responds to the gyro. The "SCALE" (rotor scale) adjusts the balance between the two rotors. If it is a smooth rotation (as opposed to a skittish, jumpy, or erratic rotation), you need to adjust the SCALE knob as one rotor is consistently faster than the other. On the other hand, if it is erratic and jumpy, randomly spinning in quick bursts, you should adjust the SENS knob. Erratic spinning is a result of the gyro detecting vibrations and overcompensating, throwing the helicopter in a circle. Play with these knobs, try just slight adjustments and keep going until it flies right. Have common sense, don't turn the knobs too far at once, just small adjustments will make it easier. Also if turning the knob one direction makes it worse, go the other direction. If you turn the SCALE knob too much you may lose lifting power because it will reduce the maximum power of one of the motors.
Posted on Jun 02, 2009
  • 199 Answers
SOURCE: I recently bought a Walkera 43g heli with a 2801
This sounds like low power on the receiver BEC or the transmitter battery power. Check the voltages and cell polarities. You should not be getting interference with the 2.4 G system. If this is not the problem then I would send it back.
Posted on Aug 17, 2009
SOURCE: i have an apache 3 channel helicopter.the top
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
male_28_cam
  • 1555 Answers
SOURCE: i need to know what
I'm providing you a link below for the motor which is available for 19$ online suitable for your heli.
http://www.hobby-wing.com/hm-68b-z-38.html
Posted on Mar 27, 2011
My upper rotor does not always power up when i throttle up on my walkera 5#10. i have replaced motors with new factory motors thinking that was the problem but same problem
Hi, I had this same problem but its my bottom rotor that wont throttle up. Before you bind put the throttle in full. After it binds return the throttle to min. and its ready to go. I hope this helps, although its not a fix. It a cheap one $$$.
Sep 16, 2010 | Walkera HM5#10 RC Helicopter
Walkera lama 400 just spins round
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Sep 12, 2010 | Walkera Toys
Walkera 60 helicopter problem
thank you very much, i like your article
and i have the same problem
RC airplane
Freewing RC airplane official site Flightline Official site Freewing model...
Apr 17, 2017 | Walkera Toys
Hello, Is there a manual in english for the Walkera 2.4 GHz HM5#10RC that shows assembly and adjustments for the servos. Thanks
i have a 1996 chev blazer and when i turn it on the fuel pump keeps going and fills the base with gas,and thevehicle won't start
Sep 09, 2009 | Walkera HM5#10 RC Helicopter
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Walkera Dragonfly #68 7 Channel 3D Aerobatic Radio Remote Controlled Electric Rc Helicopter Ready To Fly Logo
224 people viewed this question
Top Walkera Toys Experts
Michael Galve
Michael Galve
jasen linko
jasen linko
Are you a Walkera Toy Expert? Answer questions, earn points and help others
