Question about Panasonic Office Equipment & Supplies
I want driver for Panasonic KX-P1121 for XP
  • Nicolas
    Nicolas May 11, 2010
    That printer is including in XP as standard printer acording to panasonics site:
    Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
    Category
    Model
    Monochrome Laser Printer
    KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL)
    Dot Matrix Printer
    KX-P1081, KX-P1121, KX-P1123, KX-P1124,KX-P1124i,
    KX-P1150,KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123,KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
    So there arent any drivers for download
    Good luck
    Nic
Help,,,,please solve the panasonic kx-p1121,cannot print,still status off line ? why cannot use?? somebody can help...TQ Verry much....
Posted on Jun 07, 2011
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: how to get panasonic printer driver kx-p1121
http://www.printcountry.com/drivers/PANASONIC_KX_P1121_DRIVER_DOWNLOAD.htm
Posted on Jun 09, 2008
AvioriX
  • 689 Answers
SOURCE: panasonic kx-p1121 driver
Dot matrix printers usually work with IBM compatible native drivers. I have tried similar model with Vista worked fine. You may need to perform manual installation by using LPT1 parallel port. If you cant see similar model in the list you can choose generic text printer or IBM Proprinter.
Good Luck
Posted on Nov 10, 2008
  • 132 Answers
SOURCE: can't find printer driver for
HI.................... NEED Panasonic KX KX-P1121 Printer Drivers???
panasonic_091012_021220_128.png NOTICE: Panasonic's current KX KX-P1121 driver release resolves driver conflicts, improves your computer's stability and restores communication with all KX Printers. The newly released KX KX-P1121 drivers are a high priority update recommended for all Panasonic users.
Description Version Estimated Download Time KX KX-P1121 Driver
(Includes, WHQL certified drivers)
Current as of
(Sep 26 2011) 56K: ~9m
512K: < 1m download.pngDownload
Installation Instructions:
  1. Click above Download link or Click here to begin installer download.
  2. Click "Run" ("Save As") if using Firefox
  3. Click "Run" Again
  4. Follow on-screen prompts to complete installation.
Important: If you are using Firefox or Netscape as your browser, you will be directed to save the application "to disk" (we recommend that you save the application to your desktop).
We recommend that you save it to your desktop and initiate the free scan using the desktop icon. Should you choose not to save the application, you may simply initiate the free scan by clicking the "Run" button on the File Download Window.
You can also search for a specific driver below:
Locating updated drivers is easy! driver_manufacturer_123.png driver_select_4.png Download Drivers New Version Of Windows? No Problem!
Upgrade smoothly by finding the correct drivers for your KX KX-P1121 printer for Windows XP, Windows Vista or Windows 7. For the first time, users can upgrade with confidence knowing that their computer will run smoothly thanks to the latest drivers and updates required for a perfect upgrade.
Why Updating Drivers Is Important
Usually the only reason we look to install or update drivers is because something is malfunctioning. This is not the only reason you should keep your drivers up to date however. Panasonic is constantly tuning and improving performance of their KX KX-P1121 printers and the only way to make use of this is by having the latest drivers. Going online and checking for new drivers all the time can be frustrating and is not an effective use of your time, and a simple tool like the driver installer above can keep all of your hardware running on the optimal drivers with top performance.
Sometimes when new hardware is installed, although it works correctly, other hardware which interacts with it may not be, because the other hardware actually needs its own drivers updated. This kind of co-dependency is another common problem and a reason why it's a great idea to have a tool that is constantly monitoring the state of all of your drivers and updating appropriately so you can upgrade and add or remove components in your computer while continuing to run without a hitch.
When your KX printer is relatively new, it may be possible to download individual drivers directly from Panasonic without incurring additional charges. If you are having problems locating the correct drivers for your Printer printer, or are unsure of the exact model, we suggest you run a system KX scan first. It's very important you know the exact model of your Panasonic KX KX-P1121 printer you would like to update to ensure that it will function properly and to prevent possible damage to your system. Click here to download an installer that will automatically scan and identify your Panasonic to make sure you are installing the correct update and will also locate and download any additional driver and bios updates your pc may need.
recommended.png Install the latest KX driver updates now.
  • Automatically Updates Panasonic KX Printer drivers and all orther missing or out of date drivers using advanced scan technology.
  • Instant access to unlimited device drivers.
  • Starightfoward and intuitive interface
  • Better PC performance and improved stability
  • Access to the largest drivers database in the industry
  • Continous updates for the latest manufacturer drivers
  • Unlimited free technical supports with our 24x7 technicians
HERE IS THE LINK OF DOWNLOADED FILE.....................
http://xpdrivers.com/printer/panasonic/kx/kx-p1121/_5_5908.cfm
GOOD LUCK..................
Posted on Sep 26, 2011
In need of the panprint01 driver, lost the cd ... help please
Go to the product support website of the maker of the printer to download the printer drivers. Also in the future always in include make and model of the printer.
Jan 10, 2017 | In Office Equipment & Supplies
Can I network Shinco printer s2145
with one of these
http://www.dx.com/p/network-usb-2-0-lpr-printer-server-10-100mbps-ethernet-31570?tc=AUD&gclid=CP-1weaL9MICFRUIvAodEpYAZA#.VKXrgHs_zLk
Only thing is I did not find windows 8 drivers for this printer as standard so you may run into trouble with computers running windows 8 as each computer has to have the exact operating system printer driver designed for its exact operating system .
Unless you can find windows 8 drivers somewhere on the internet
Jan 01, 2015 | Office Equipment & Supplies
Samsung SCX-3201G printer driver free download
Samsung SCX-3201G printer driver no download plzzzzz help me
Jun 21, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
I have a hp photos mart d7360 printer and do not have the disk to instale
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select your operating system to download the appropriate drivers and software.
Hope this solves your problem. Thanks.
Nov 13, 2009 | Office Equipment & Supplies
How can i download driver of samsung ml 1610 mono laser printer
Nov 18, 2008 | Samsung ML 1610 Laser Printer
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
4,956 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
