Question about Compaq Presario C700T Notebook
Install windows xp
I have a laptop presario V3000 model no.3777TU with windows vista basic i want to install the xp but hard disk driver is not supported what to do
  • 33 Answers
Hi alpeshsparma,
here is the link to the driver you're looking for:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&dlc=en&cc=us&product=3671001&os=228〈=en
Greetings from Germany,
noris017
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 25, 2009
Compaq presario v3000 sound driver xp
Normal 0 You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Oct 01, 2010 | Computers & Internet
Hp compaq presario v3000 model pcl driver is not working and Audio device also not working. please tell me the link to download. thanks
<span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -<br /><a href="http://www.compaq.com/country/cpq_support.html">www.compaq.com/country/cpq_support.html</a></span>
Aug 25, 2010 | HP Compaq Presario v3000z Notebook
I have a compaq presario v3000 i remove the vista now xp is running on my laptop but drivers are not working after change the os.
The model "V3000" is a generic term for a bunch of different models. To make sure you get the right drivers for your specific model, start at HP's site here and pick yours from the list. Then pick the Windows XP operating system and you'll find the drivers they have for download.
Mar 08, 2010 | Compaq Presario R3000 Notebook
I tried to install the XP in my laptop compaq c700 (vista basic ) getting the error " replace the hard disk"
Greetings my friend, please try to format first your hard disk before installing Windows XP to prevent error causing by the vista operating system setup settings.
Thanks
Jan 07, 2010 | Compaq Presario 700 470024-192 Notebook
Ethernet controller driver missing for Presario V3000 with windows vista home basic.
click here
Then select your model and then operating system then downlaod ethernet driver for vista.
Then install then it works fine.
Let me know if you need more assistanse.
Thanks.
Sep 22, 2009 | HP Compaq Presario v3000z Notebook
Mic problem in presario v3000 WIndows xp
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
May 29, 2009 | HP Compaq Presario V3000T Notebook
How want to downgrade win vista to xp pro hp compaq v3000
If you have a Windows XP Pro installation disk, put it in the optical drive, restart your computer, on startup, go to BIOS settings (usually press [Delete] and set the optical drive as first boot device. Save changes and exit. When the computer starts it usually says to press any key to start from CD. Press any key and the windows installation will start. Make sure you format C: and you will downgrade to Windows XP Pro. If you want to upgrade to Vista again, you will need to know the keyboard sequence to start Vista from Its partition or have Vista install disk.
May 25, 2009 | HP Compaq Presario V3000T Notebook
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Compaq Presario C700T Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
