Question about Yamaha HTR-5630 Receiver
Yamaha htr-5630 panasonic dmr-xw300 compatability
I have a yamaha htr-5630 av receiver and just recently purchased a panasonic dvd recorder dmr-xw300, when i connect them the amp only shows that the front left and right speakers are working, I have done the setups as indicated in the manual and when the amp does its check it shows all ok then switches back to left and right. From the dvd to the plasma is a hdmi cable, from the plasma to the amp is an optical cable and from the amp to the dvd is a coaxial cable. What am I doing wrong can any body help, Thanks
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
mlapres
  • 757 Answers
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
  • 92 Answers
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Posted on May 20, 2009
DVD disc is stuck in Panasonic DMR-XW300 DVD recorder but somehow child lock is showing. Cannot unlock child lock!
Try pressing and holding the OK (the center button in the arrow key section) and Return (on the lower right of the arrow keys) buttons on the remote control at the same time. You should see the X LOCK message disappear. (Holding these two buttons will toggle the lock on when it is off.) This is shown on page 89 of the manual which is available from Panasonic on the product site: http://www.panasonic.com/au/support/manual-download/players-recorders/video-recorders/dmr-xw300.html . The direct link to the manual is http://www.panasonic.com/content/dam/Panasonic/support_manual/DVD_Recorder/English/rqt9135-l.pdf .
If you are using a universal remote, the code currently in use may not match this feature. Try the original remote if you can. A replacement remote that should match all of the features is here: http://www.tvremotes.com.au/panasonic-remotes/original-panasonic-remote-control-n2qayb000273-dmrxw300gl .
I hope this helps.
Jan 15, 2017 | Panasonic Televison & Video
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
How to reset Yamaha-HTR 5630?
How to resets Yamaha natural sound receiver htr 5630
Sep 11, 2011 | Yamaha HTR-5630 Receiver
Re-recording on re-usable discs (automatically finalised)
Check the setup. You have "automatically finalize disk" selected.
Mar 15, 2010 | Televison & Video
I have a Yamaha HTR-5630 receiver. Can I add a
try use 1/4" stereo plug to two RCA plugs used with amplifiers and mixers
[img]http://www.mcmelectronics.com/images/product/icons/magnifier250.gif[/img]
use yamaha cd or aux input ..
Dec 31, 2009 | Yamaha HTR-5630 Receiver
Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
May 03, 2009 | Yamaha HTR-5630 Receiver
No sound from my htr-6030 when i hook it up to my dvd player with
If you can't use one of the Optical Digital Audio INPUTs on the HTR-6030, why don't you just use the Analog Audio Out on the HDD and an Analog Audio IN on the HTR-6030? It has one actually marked 'DVR', but any one would do.
Mar 19, 2009 | Yamaha HTR-6030 Receiver
Cannot copy video from JVC GZ-HD6 camcorder to DVD Recorder
If you can play the vision on your tv via an av connection you should be able to record it onto the recorder. the recorder can record anything thats being played on the tv even if the other device is connected to the tv via another av connection. try this & see if it works.
Mar 14, 2009 | JVC GZ-HD6 HDD Camcorder
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Dmr-ex77eb-k
The Panasonics are very picky about the media ie brand and quality of the DVD blank. Try a different brand and see if that helps.
Nov 23, 2007 | Panasonic DMR-E80H DVD Recorder
Yamaha HTR-5630 Receiver Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
