Question about Sony Handycam DCR-DVD205 DVD Camcorder
Cant record - error on display E:40:00
Cant record anymore, LED display is constantly flashing E:40:00. If i press the record button the handycam resets and comes back with the same error.
Sony are quoting me £170 to resolve!!!
  • stuart_beard Mar 02, 2009
    I tried the cleaning with the dvd cleaner but I've still got the same problems - thanks for tryinh to help with this
    President:
  • 1,223 Answers
It is a typically seems like LENS problem lens got weak and unable to record have u changed recording media tried several dvd -rw or dvd-r what are the results , can u see the lens with ur eyes if yes u can clean it with very soft cloth used to clean lcd's see if it works , other wise buy a mini dvd cleaner with brush on it may be it helps in this situtation other wise the whole lens will be replaced but this is too much for that 170 , pls try the solutions and let me know ,, do try the lens cleaning thing it works in some cases
Posted on Feb 25, 2009
Will not play DVD from other regions. Specifically, plays a few but mostly does not play DVD from Australian region. I resdie in Serbia. thansk for any advice or work arounds on this issue. We inherited...
Your dvd is locked to a region code so will only play dvd's for region it was made for.
good news is that you can unlock most dvd players to be region free.
URC-3445 ONEFORALL
First of all set the command mode of the recorder to "DVD1"
from the menu and from the remote.
After that
1. Press DVD on the remote control
2. Hold MAGIC button (or SET Button) until the led flashes twice.
3. Press 0, 5, 3 and 3 and the led flashes twice.
4. After that the URC can manage the recorder...check it
If not, then use the code search (have a look in the manual of the remote control).
When the rc works, then step over to
MAIN PROCEDURE (DON'T HAVE ANY DVD INSIDE THE PLAYER)
1. Hold MAGIC button until the LED blinks twice
2. Now type "994" (then LED blinks again)
3. Press the MAGIC button (shortly)
4. Now type 001891
5. LED blinks twice
6. Repeat steps 1-5 and enter instead of step 4 the codes 002552,000953,002214,000795
7. Put the player on standby (and be sure that there is no DVD inside)
8. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes on
9. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes off
10. Then it is done. Your DVD-Player/Recorder is Codefree
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony SLV-D990P DVD Player/VCR
Toshiba RD-XS35SC error 14 flashes constantly
Press the "Display" button a few times to clear the error.
Dec 12, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Cant record
Set that switch to Camera to record live view. Press red button to start recording and press again to stop recording.
Apr 17, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Error display C31.23
code indicates that you should remove the cassette and insert again, then operate camera.
disconnect power cord and battery pack. after reconnecting operate camera,
Oct 13, 2008 | Sony Handycam DCR-TRV30E Mini DV Digital...
Disk access issues
Clean dvd lens inside dvd compartment with fine n soft cotton swab carefully.
Jul 19, 2008 | Sony Handycam DCR-DVD201E DVD Camcorder
Nokia 3230 video problem
flash the phone and use again . code to flash is *7780# AND *7370#
Jan 21, 2008 | Nokia 3230
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Handycam DCR-DVD205 DVD Camcorder Logo
303 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
