Question about Ricoh Aficio GX3000 All-In-One Printer
It keeps syaing remove misfeed guide board. I cant print though the paper that jammed was removed
flopez
  • 161 Answers
SOURCE: Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Posted on Oct 04, 2007
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Posted on Feb 07, 2008
  • 41 Answers
SOURCE: Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Posted on Feb 22, 2008
  • 10 Answers
SOURCE: Mysterious paper jam or misfeed
You can take it to BestBuy for service, as they are an authorized service provider for HP, but you can expect to pay for a repair.
-Remove rear access door and thoroughly inspect for ANY tiny pieces of paper. The smallest ones can be a HUGE problem.
-Remove ink cartridges and printheads. Close doors. Disconnect power. Wait 30 seconds. Reconnect power WHILE holding #,6 on the keypad. This will perform a thorough reset of the unit.
A costly potential fix is new ink cartridges. Even though cartridges print fine, they CAN cause something like this but unfortunately it is more likely a waste of money than a fix.
If you are unable to find your receipts and the above did not work for you, the only other thing you can really do is call technical support and escalate the case. Insist to speak to a supervisor, then a supervisor's supervisor.
Posted on Jul 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
Remove Misfeed B Fusing Unit Error- After 1 page is printed
just open the printer and check for any dislocation of the sensor or levers.
Apr 26, 2008 | Ricoh Aficio AP3800C Laser Printer
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
LEXMARK X7550 JAMS &MISFEEDS TROUBLESHOOTING
How to clear and avoid paper jams: To clear the paper path: 1 Pull firmly on the paper to remove it. If you cannot reach the paper because it is too far into the printer, lift the scanner unit to open the printer. 2 Pull the paper out. 3 Close the scanner unit. 4 Press check. 5 Reprint any missing pages. To avoid paper jams, do not force paper into the printer.
The Lexmark X7500 Series User's Guide will be able to give you more detailed instructions on how to troubleshoot paper jams and misfeeds on your printer. You can download the user's guide from the Lexmark website at http://bit.ly/mdAcJO and go to page 177.
May 10, 2011 | Lexmark X7550 InkJet Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Check paper loading Load a smaller amount of paper into the printer.
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Adjust the paper
guides
Adjust the paper guides:
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Paper jam
I would like to inform you that this might cause due to dirty paper rollers hence Please click here and follow the instructions to resolve this isse.
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Jul 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam 2
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Ricoh Aficio GX3000 All-In-One Printer Logo
223 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
