Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Printer wont operate
Purchased new printer DCP165C- it was faulty so it was replaced with a new one i put the disc in to connect, said it was already connected. tried to print - nothing happens
  • 530 Answers
Hi im josh in cebu phils.may i help you friend? Friend if your new printer wont operate because an old software was installed already,thats why it says it was already connected and everytime you install the cd it will counterfieit the new software. so to solve this problem you remove first the old version of printer driver installed in your pc.go to control panel and and remove progrms then you remove the old driver there then reboot your pc. after rebooting install now your new printer driver together with your new printer. thats all hope i helped you.good luck
Posted on Feb 25, 2009
  • Joseph Baculan
    Joseph Baculan Feb 25, 2009
    hi im josh in cebu phils.may i help you friend? Friend if your new printer wont operate because an old software was installed already,thats why it says it was already connected and everytime you install the cd it will counterfieit the new software. so to solve this problem you remove first the old version of printer driver installed in your pc.go to control panel and and remove progrms then you remove the old driver there then reboot your pc. after rebooting install now your new printer driver together with your new printer. thats all hope i helped you.good luck
I keep getting the %buildtemplateerrormessage% when I try to delete this. I no longer have access to the printer. How do I get rid of it?? It's like gum on your shoes!! HELP!!!
What operating system are you using ?
1. Disconnect your printer from the pc. 2. Uninstall your printer's drivers. 3. reboot 4. put your original printer's CD and follow the instructions.
in case you dont have a CD Connect your printer to the computer, if you have Windows VISTA or Windows 7 maybe you wont need any driver cause windows already have one. In any other case connect to the internet and let windows find a driver for you (see instructions when locating new device and asking for drivers)
Jul 28, 2011 | Computers & Internet
Ive got a notebook laptop and i want to get an epson stylus dx4400 and i havent got anywhere to put the disc in can i still use use the printer
You should be able to download the driver online from the epson website. This would allow you to install it without using a disc. Depending on how new your operating system is and if the printer is connected via usb, it may auto install the drivers for the printer once it is connected.
Jul 21, 2011 | Computers & Internet
Came off computer next time i went on i could not get any thing on computer i can not get windows or anything i have even tried using the discs to put laptop back to facyory settings and it wont even let...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 05, 2011 | Microsoft Windows Vista Home Premium with...
CD drive wont read on my brand new e627
Hello, Jennifer.
Since you just purchased the emachine two days ago and already there is a problem, I would suggest that you either return the computer to where you purchased (most place have a 7-day return policy) or contact emachines. Here the link to emachine's Customer Care: http://www.emachines.com/support/warranty.html
I suspect that the CD drive is faulty and should be replaced.
Hope this helps.
Nov 30, 2009 | Computers & Internet
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
Installation software for printer
Choose your operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=391186&lc=en&cc=us&dlc=en&lang=en&cc=us
Disconnect the printer before installing the software and only connect it when asked.
May 12, 2009 | Office Equipment & Supplies
Canon MF 4350d Wont install
Almost the exact same problem. New 4350d Canon printer trying to connect it with Dell 8300 with XP. The computer says it does not recognize. Tried everything - reinstall drivers, download drivers, tried every USB port, swapped cables, spoke with Canon support and finally took the printer back and got a new one (Canon support person decided the USB board must be bad). New machine - same old problem.
Feb 10, 2009 | Office Equipment & Supplies
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
79 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
