Question about Fuji ASK-4000 Thermal Photo Printer
How do I clean the print head of a Fujufilm ask 4000? John.
  • 54 Answers
The printhead is a 300 dpi thermal. If you raise the head and can see the glass face, there are 2 rows of heating elements that are used in printing.
As in all thermal heads, do not use any sharp objects to scrape on the head. I usually use a non volitile citrus cleaner or iso alchohol.
The plate beneath the head should also be checked for wear and cleaned to provide positve drive for the stock.
Posted on Feb 25, 2009
Is it possible to change the print head, if so where to buy?
Posted on Aug 06, 2010
Black only text won't print
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 04, 2013 | Epson Stylus Pro 4000 InkJet Printer
Epson stylus pro 4000 i have a clogged nozzle cant move it other 7 are fine
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 03, 2011 | Epson Stylus Pro 4000 InkJet Printer
We have a Fuji Ask 2000. We have 2 problems. Our
I am experiencing the same problem but the ripple artifact does not show up on every print. rather on every fifth or sixth one. cant seem to find any support from fuji who asked for my credit card number before i even told them my problem. this item should be still in warranty but fuji would not hear it!.. horrible tech support. hopefully someone out there has found a solution
May 06, 2010 | Fuji ASK-4000 Thermal Photo Printer
Print head is clogged. Tried cleaning normal. All I got was wasted ink and still clogged print head. It is an epson 4000
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Jan 22, 2010 | Epson Stylus Pro 4000 InkJet Printer
Keeps blowing print heads
How often do you blow out your print heads? You should get several years from a printer. If disc are routinely inserted off the pins on the tray the disc will be elevated and will increase the chance of blowing out the head.
It is also important to keep the printhead clean. A dirty head will build up more heat and can cause a pixel in the head to burn out.
John Norman Max Optical LLC. 610-269-7033
Oct 29, 2009 | Rimage Prism Plus Thermal Label Printer
Epson 4000 manual head cleaning
Hey I have had my printer for 6 years and have had the same problem. I had to manually clean it and It saved me a chunck of change. I mixed equal amounts of amonia, acohol and windex in a bottle then I set my printer on replacing the blades. Once it was positioned I turned it off and removed the plastice cover over the ink tubes. With gloves I unscrewed each color from the top. The ink will run back into the tanks but dont worry. be careful not to loose the small rubber seals inside these tubes.Place a paper towel folded under the ink heads where the paper is printed on. I had a small insulin syringer that I put fluid in and I gently pushed fluid into each ink hole. I did this several times before I got the inks to flow onto the towel and I let it sit for 20 minutes or so. I then screwed all the tubes back on each color. I removed the paper towel , restarted my printer and ran a full power cleaning. Dont be concerned like I was about the ink wasted because remember your inks flowed back into the tanks when the suction was broken. You must do the power cleaning to force the air out of the chambers and you waste very little. My printer runs like a champ the first print was awesome. It takes about 45 minutes so be patient and careful.
Here is what you will need:
Paper Towels sm phillip screwdrive
Rubber Gloves small syringe
Solution /acohol-amonia-windex
A lot of Patience
Mar 21, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Re Canon Pixma 4000 black ink is not printing colours are printing Computer not used for 6 months
Canno ip 4000:
please go to the maintenance tab.
This you will find if you try to print anything.
In the print box >go to properties>go to maintence
Here the following Maintenance option are there:
deep cleaning,
Head Alignment,
Nozzle check.
Before your start maintenance, please check whether all print tanks have ink in them
Do a Nozzle check first, this will indicate where you have the problem. Once identified, you can do a color cleanig or a deep cleaning.
Do a Nozzle check again.
You could repeat this cycle about three times or so.
If your problem still persists, then its probably the Print head with jammed nozzles.
Please let me know whether you could solve it.
Please do rate this solution and thanks for using FixYa.
Mar 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Blue and sometimes red lines all across the prints using an epsom 1290. cleaned heads numerous times. nozzle check OK
Hey, sounds like the print heads, but replacing all the cartridges is best option first sometimes fixes the problem, if it dont you should look for epson 1290 cleaning cartridges on the internet they aint expensive, as head cleaning doesnt always unblock the print heads...
All the best
Jul 26, 2008 | Office Equipment & Supplies
Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Jul 12, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Problem with canon pi 4000
I think you have to clean the print head.and if cleaning doesn't help you may have to get a new print head.
May 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Open Questions:
See all Fuji ASK-4000 Thermal Photo Printer Questions
Fuji ASK-4000 Thermal Photo Printer Logo
398 people viewed this question
Top Fuji Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
