Question about Fuji ASK-4000 Thermal Photo Printer
Hi. I have a fiju ask 4000 and it has started to print slightly off line on the paper leaving a white border on the bottom and one side of the print. This border is about 4mm on the left and goes down to about 1mm on the right. Can you help please? John
  • jkphoto Feb 25, 2009
    I would have thought that the head or something was out of line or something? would dirty heads caus this problem. The white border is very clearly defined as if it was a deliberate border. John.
  • Fuji Master
  • 19,396 Answers
There should be an alignment procedure listed on the printer software utilities.
If the alignment procedure does not work, there is also a mechanical alignment procedure, that can be done by calling Fuji and following the step-by-step guidance.
Posted on Feb 25, 2009
  • 6,487 Answers
Do some maintenance cleaning on the print head of this printer and that should fix it...
  • Mark Gil
    Mark Gil Feb 25, 2009
    Yes a dirty head can cause that problem that's why it will be better first to do some cleaning...
I have a hl 5140 printer and there are lines on the side of the page when it prints.
Hi
Hope I can solve your problem
The first thing is do you go to print preview before you print if you do and the line is there it might have something to do with your page border go to your page border and put on no border
It also might have something to do with not having your paper correctly in the printer make sure all your paper is the same in the printer and it is all straight
and correct at the time of print.
but my bet is that you have your page border on 1 side of your paperwhen you are doing a document up the top you have page borders make sure it is on no page border
I hope I helped
Jan 22, 2010 | Brother HL 5140 Laser Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
White border on edge of print
The only way would be to use a bigger piece of paper and cut it down to the size you need...... The copier will always leave a white border a round the edges.... It is done so the toner can be fixed into the paper with out off setting or jamming
Mar 14, 2009 | Kyocera Mita Office Equipment & Supplies
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
HELP
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
May 29, 2008 | Microsoft Office Computers & Internet
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Open Questions:
See all Fuji ASK-4000 Thermal Photo Printer Questions
Fuji ASK-4000 Thermal Photo Printer Logo
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
