Question about Microsoft Xbox 360 Wireless Controller
X-box 360 controller will not switch on
Batteries are fine, inserted the correct way etc. I have tried re-chargeables and ordinary AA ones but no luck.
The controller just would not switch on one day.
Is the controller dead & needs replacing?
Is this a common occurrence, or is there an easy fix, something obvious?
The controller is wireless, by the way.
  • thepilgarlic Mar 14, 2009
    Thanks, I tried some more batteries and it turns out that you are right, it just doesn't seem to like some types, including my rechargeables.
    Problem is, now the darned console has the red ring of death...
Sometimes you have to beware of unknown batteries, because some companies that make the batteries are fake... However, look below for some of my FAQs (Frequently Asked Questions)
1. My battery pack won't does not work, and/or it will not turn on...
First, make sure that you have the right batteries that are known like Duracell. Next, DO NOT plug in the charger into your controller when you have AA batteries in your battery pack. Then, make sure that you press and hold the sync button of your Xbox 360 console, and your controller.
2. My wireless controller automatically turns off during gameplay...
First, make sure that you turn off the vibration of your controller, because the vibration takes away your controller's energy, and the lease power your controller will have. Next, please read the Frequently Asked Questions guide for wireless controllers, because there are some important steps about the wireless controllers. They usually have the problem with charging and changing AA batteries.
I hope that it was helpful, and if you have more questions, then you contact me at my gamertag, NussKarte. Good Luck! ;-)
Posted on Mar 14, 2009
  • NussKarte Mar 14, 2009
    Sorry for interruption, but I made a mistake...
    "1. My batterpack won't work, and/or it will not turn on..."
    I just wanted to fix it... ;-)
How do I get my PS3 afterglow controller with a chargeable battery installed to connect to my PS3 system. (afterglow controlder does not take AA batteries).
Afterglow AP 2 has a flat nickle battery
upgrade your controller
i take it yours is not a wireless
PS3 wireless afterglow controller uses aa rechargable
Mar 31, 2017 | HOW Video Game Consoles & Games
NOT SWITCHING ON
1. Try using batteries that are charged in a "different" charger.  Rechargeable batteries designed for cameras are interchangeable as long as they are the same "type" (ie. AA, AAA,etc)
2. I suspect it is the "charger" that is not working correctly.  Take it back if its covered under warentee.
3. If it isn't under warentee buy a new charger or buy re-chargeable batteries with a "high" power rating 1800 Ah plus that come with a charger.
4. If all this fails then you need to go back for replacement or repair depending on your warentee situation.  But try the number one first.
Oct 30, 2007 | Fuji FinePix M603 Digital Camera
Want battery-pack
In reviewing the product, it appears that the batteries are inserted directly into the radio. (no case or adapter to fit a battery module in) Buy re-chargeable 2500mh batteries.
Jan 24, 2015 | Binatone 100 Latitude Walkie Talkie twin...
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
How do i connect a wireless x box 360 controller to my x box
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected
Each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button.
Jul 04, 2011 | Video Game Consoles & Games
My 360 control won't turn on I ve switched battery pack and still won't turn on with brand new batteries
Are you batteries correctly inserted into the battery pack and fully charged?
Have you tried pressing the smaller "connect" button on the controller as well as the "connect" button on the console?
May 04, 2011 | Microsoft Video Game Consoles & Games
Controller will not stay connected. continuously stops game and says "please reconnect controller
How to connect a wireless controller
  1. Press and hold the Guide button on the controller until the controller and the console turn on.Press and release the connect button on the console.Within 20 seconds, press and release the connect button on the controller.When the lights surrounding the power button on the console stop flashing, the controller is connected.
    • If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
Dec 28, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 Wireless Controllers Not Working
Have your Xbox 360 controllers replaced, it still has warranty, i presume. Any type of batteries would work, especially energizer, but you can try the original Xbox 360 controller batteries (rechargeable ones). Xbox 360 Tech Support....
Jun 05, 2010 | Microsoft Xbox 360 Controller
I have a Kodak Digital camera that came with Kodak batteries. I used those batteries for something else and have tried using different brand batteries in the camera but it won't work. The camera was a Xmas...
By the sounds of it, I'm assuming the camera takes AA cells, not a proprietary special cell?
Are you using heavy duty alkaline batteries (such as Duracell), or ordinary zinc carbon ones? Digital cameras have a very high drain on batteries, to the extent that ordinary zinc carbon batteries cannot provide the required load, and often fail to even get a camera turned on.
Top of the AA cells currently is Lithium, next down the pecking order is Duracell M3, then ordinary Duracell Alkaline (It doesn't help that they are called different things in different markets - I'm based in the UK).
The other inital check is to ensure they are inserted correctly. Most cameras have a small sticker, or engraving inside the case, to indicate which way round each battery should go. (Make sure you follow the correct orientation for each, as just one the wrong way round will damage the others to a state of unusable within minutes).
Please try again with some decent batteries, and if it fails to turn on, add a comment with the camera model and we can go through other steps to get it to power up.
If unsure, wander into any camera shop (without batteries in the camera), and ask them to put some in for you. If they can't get it to power up, send it back under warranty.
Feb 26, 2010 | Kodak Cameras
Microsoft Xbox 360 Wireless Controller Logo
430 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
