Question about Xerox DocuColor 3535 Copier
How do i reset the second bias transfer roller on a Xerox 3535?Thanks, chris chris@supplyprint.co.uk
You need a Xerox service laptop to communicate with the beast and reset it, that is what I was told by a Xerox Tech, Nasty I know but no other choice they got you.
Posted on Feb 26, 2009
  • 33 Answers
There is no possibility to reset the second BTR using user interface.
You will need a technician with a proper laptop with COM1 port...and a proper program. Sorry to say but it is an END-OF-LIFE product.
The machine works all right with the message flashing. No need to reset it. Did you really change the 2nd BTR anyway? When its bearings get jammed you will be in BIG trouble.
Posted on Nov 29, 2014
COMO RESETEAR EL SEGUNDO ROLO DE TRANSFERENCIA DE UNA COPIADORA XEROX DOCUCOLOR 3535 ??? EMAIL: an.bernal@codetel.net.do
Posted on Mar 09, 2009
What does a second transfer bias roll do
It simply drives the transfer belt which is required to lay the image down on the paper.
Depending on which Xerox product you have would depend on whether a service tech is required to replace one that has failed or whether it is a roller that can be easily replaced by a non tech saavy individual.
I hope this helps...
Mar 09, 2015 | Xerox Phaser Office Equipment & Supplies
How do I reset 2nd bias transfer roll for xerox 7556
On the 7556 and most other Xerox copiers, follow these steps to reset the counter. You do NOT need to call out a tech.
The supply life counters must be reset when some supplies are replaced.
  1. Log in as the System Administrator or Key Operator.
  2. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
  3. Select the [Tools] tab on the Touch Screen.
  4. Select the [Device Settings] button.
  5. Select [Supplies], and then under Features select [Supply Counter Reset].
  6. Select the required supply item, and then select [Reset Counter].
  7. Select [Reset] when the confirmation screen is displayed.
  8. Select [Close].
  9. Press the [Log In / Out] button on the Control Panel. The Logout screen will be displayed.
  10. Select the [Logout] button on the Touch Screen to exit.
Feb 11, 2013 | Xerox DocuColor 3535 Copier
Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Apr 12, 2012 | Xerox DocuColor 3535 Copier
FAULT CODE 094-322. WHAT CAUSES IT AND HOW DO I GET RID IF IT?
ERROR CODE 094-322 RAP Second BTR Retract Failure
The error relates to the Second bias transfer roller not retracting. It could be a fault with the roller but i would open the transfer draw and check the connections and seating of everything and try it again. More often than not this clears the error.
Jun 24, 2011 | Xerox DocuColor 12 Color Copier
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Docucolor 3535 Second Bias Transfer Roll - Replace Soon
Just plug the new one.
But you wil need to reset with diagnostic programme.
Jul 04, 2009 | Xerox DocuColor 3535 Copier
I am afraid you will have to call in a qulified xerox technitian to reset the second bais transfer roll. It need to be done via a laptop connected to the m/c. The laptop needs to have a special program which only xerox techs. have in there possetion.
George
Jun 02, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Nov 25, 2008 | Xerox DocuColor 3535 Copier
Xerox DC3535 Color Copier
No unfortunatly. That is done in the diagnostic mode on the 3535, and that is propritary sofware where the diagnostics has to be accessed with a laptop that has that software loaded onto it.
There are some resets you can do, but they wipe out all the NVM inforamtion. Once those numbers reach a certain level, they have to be reset via a laptop.
Now that being said, once it is accessed, the service rep CAN change that threshold to a much much higher number so you can run the parts to failure, which is more realistic.
Those parts are very easy to replace. And can be purchased from a business called The Parts Drop, Google that business and talk to Britt. No I do not work there, but have dealt with them for years and they are very professional and exceptionally honest.
Jul 08, 2008 | Xerox DocuColor 12 Color Copier
1,010 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
