Im having problems with receiving and sending mms. When i go to retrieve the mms it says its downloading this usually takes 3-5 minutes and then says it failed. Or when i try to send the message i add the image it works then i go to send it and it says the image is too large. Ive tryed many things but i dont have a manual so i cant check the settings for help. Ive even brought a new memory card. NEED HELP PLEASE.
Unfortunatly these phones can only send up to (usually) 128kb and recieve up to 50kb. That isn't that big but there is nothing you can change on the phone to make it work. You can resize the pics and try to resend, and have friends send you smaller pics.
MMS is one of the feature of the mobile service that you have. You are using smart for your mobile service,right? There are settings on the phone that should be taken cared of for you to have access with other services. MMS is one of them. Once MMS setting is not yet set on your phone,once someone sent you MMS, you will not be able to retrieve it nor open it for your MMS settings were not yet installed,it seems not activated. You need to call smart for them to send you the settings. Once you recieved the settings via sms,just save it. For you to check if its working for sending and recieving,just send an MMS to your own number.
The settings of MMS and Mobile internet (GPRS) are provided by the service provider.
Call your SERVICE PROVIDER and ask for the settings of GPRS and the settings of MMS for your
mobile.
They will send it to you as text messages,you will get two messages.
When you receive them save them and turn your mobile off for 3 minutes then turn it on.
The MMS and the INTERNET services in your mobile will be active .
You should check MMS profile setting. The proper setting should be configured before sending or receiving MMS. To retrieve the MMS automatically, you should set the settings at "Auto download" settings. To check,
1. Go to Message from the idle screen.
2. Go to "Settings" and then "Multimedia messages."
3. Select "Receiving options" and "Home network."
4. Go to "Foreign network" menu and check the status
5. If it is set at "Auto download", you can receive MMS automatically.
6. If it is set at "Manual", you should operate MMS retrieve function manually.
if you are using an unlocked device on at&t's network you will not be able to ever send/retrieve the mms messages, the reason for this being that at&t does not support the use of internet on an unlocked phone, and in order to send/retrieve the mms messages you must be able to connect to internet.
Let www.sciphonesettings.co.uk take the pain out of configuring your Sciphone/CECT handset to enable GPRS, WAP, MMS and Webmail. You could be surfing the web and sending/receiving multimedia messageswithin 24 hours
1. Press Menu 2. Scroll to and Select Messages 3. Scroll to and Select Create 4. Scroll to and Select SMS/EMS or MMS or MMS Templates 5. Scroll to and Select Insert 6. Scroll to and Select Sound
The ringtone download is through EMS or MMS. When you receive the EMS and MMS from another party, you can retrieve the ringtone from an EMS or MMS message. You can also send the ringtone by sending an EMS or MMS.
