Question about Canon iR 2016i Black and White Copier
My estudio photo copier appear service error code f14
  • didi2005 May 11, 2010
    For 160 series, F14 indicates Scanner unit F-ROM error. It is the model u r having?
Canon ir 2016 error 354
Posted on Mar 13, 2009
  • samyswaby Mar 13, 2009
    canon ir 2016 error 354
    error codef14
Showing error code F14 of estudio 225 toshiba machine. what should i do?
Hopefully you've turned it off and back on this illuminates many issues with a product that is more like a computer than a copier. Many of the hot section codes are F then 3 digits if you're not warming up at all it probably will need a Toshiba tech to either reset the code after insuring it won't go into thermal meltdown(you don't want that;trust me) and or replace a safety fuse that saved your machine by blowing. either way does it try to warm up? or it won't let you do anything from minute 1? some times on the newer models the user manual gives at least a clue to the origins of codes thrown, ie. check side door, or close fuser cover panel...... hope it helps but a thrown code is just that something needs a looked at and if it's not real obvious maybe a good service call is what you need. hint: All Toshiba tech's are required to clean/vacuum and make sure the copies are acceptable,it might be be hove of you to get rid of a peskie line going down your copies or even a ugly paper jam when you do double sided copies. good luck! Ex-toshiba tech 23years..~~~~~>SC
Sep 12, 2014 | Toshiba E-Studio 223 Multifunction Copier
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
Estudio 161 4h error code
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
Mar 19, 2011 | Toshiba E-Studio 161 Copier
Toshiba estudio 166 error F14
la stampante si resetta continuamente
Sep 26, 2010 | Toshiba e-STUDIO166 Printer
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
Toshiba estudio 45 error cc9
CC9 indicates Upper stack tray lift motor is abnormal on finisher MJ-1011. U need to check the wiring and sensors.
Oct 19, 2009 | Toshiba e-Studio163 Copier
Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 27, 2009 | Toshiba e-Studio163 Copier
Call for sevice
Correction, you need to press "clear" and "8" simultaneuosly and hold to display error code...
Apr 13, 2009 | Toshiba Estudio 200L Copier
Canon iR 2016i Black and White Copier Logo
250 people viewed this question
old marine
old marine
