Question about Canon PIXMA MP150 All-In-One InkJet Printer
Doesnt recognise refilled catridge of canon pixma mp145
I filled canon pixma mp145 catridge but it says its empty and doesnt print
  • chechii samson
    chechii samson May 05, 2009
    i have d same problem. it doesnt recognise refilled catridge of canon pixma mp145. and now our printer doesnt work.even for xerox & scanning. it says error. anyone can help me?
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back. 3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
(at this step, i press and hold the reset button twice, each time i press and hold is about 5 seconds. then i'm able to continue to the next step)
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don't worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
(at this step, i have to wait for about two minutes or more then the printer automatically start print the document mentioned.)
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
11) close the printer cover. Wait for 2 mins. (for my printer, i didnt wait for two minutes, the light immediately disappeared) The amber light beside the black ink and color ink will have disappeared.
Also if you take printouts now you will no longer get the ink low warning.If you check the ink status
it will show that the cartridge is full !!! The ink level has been reset successfully."
PS: I did not solve this myself just copy and paste from other source but I tried it and it works.
Posted on Feb 17, 2010
What is the cartridge number of canon pixma mp145
Posted on Apr 29, 2009
The chip quite likely needs resetting.
Pop along to your local Cartridge World, they'll be able to assist you
Posted on Feb 25, 2009
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
After restoring blank ink in MP145 the computer doesn't recognise
This is mainly a result of dirty contacts. The contacts between the catridge and the connective socket is either loose of not clean or to say Dirty. Try cleaning the contacts with alcohol. Also make sure that the ink catridge is supported by your printer.
Sep 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,720 people viewed this question
old marine
old marine
