Question about HP PSC 1210 All-In-One InkJet Printer
My hp 1210 psc all-in-one have a problem when i print have a messaga that said 'load more paper' i try to load more but suddenly it they same message i seen.
    Sergeant:
  • 199 Answers
Try clean the printer with vaccum cleaner and try again
Posted on Feb 27, 2009
My HP PSC 1210 will not feed the paper through
Try removing the paper and replacing it with a heavier paper > pull out the 20# copy paper and replace it with 24# bond or 60# offset. ( The 24# and 60# are the same weight just different finishes on the surface ). Assuming your paper tray is one that slides in and out, close they tray firmly. Turn the printer off, wait 10 seconds then turn it back on. If the problem is still there, look VERY closely at the edges of the feed tray / compartment. There will be a very thin wire that the paper will depress when it is loaded into the feeder. If that wire gets bent the paper may not reach it to depress it. The printer does not sense any paper if this happens. Bend the wire outward so the paper can depress the sensor switch. Hope this helps.
Mar 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer says out of paper. paper added still wont print
The solution to this is bizarre but worked for me.
In Vista press the windows key and R button. The Run window opens and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which opened in the previous step.
3. Right click on it and select Restart.
Your printer will print a self-test page but then should be good to go.
Nov 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc 1210 all in one printer
Hi there Jack. My name is Alex and I am here to help solve your problem.
This problem is common, when the software (HP director) or possibly the driver may get corrupted due to a system crash. To help solve this problem, i would reinstall the drivers and software to your printer if you have it with you.
If you dont have any software disk for this, then you can install it from here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-19447-3&lc=en&dlc=en&cc=us&lang=en&os=228&product=90764
I hope this helps you. Please let me know how you get on.
Nov 03, 2008 | HP PSC 1210 All-In-One InkJet Printer
Problem getting the printer to print with the correct alignment
is the printer connected to the your PC ?? ARE YOU PRINTING THIS SIZE directly from the PRINTER ?? AS soon as i get an answer from you , Ill tell you what to do next , thanks AJ
Apr 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printing bussiness cards
Not useful. I use CardFila.com to collect all business cards on Iphone. You can do this on Android, computer, laptop.
So easy to collect, find and use any contact at any time.
You can access the contacts everywhere without Internet connection by using CardFila for Mobile
Feb 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper Jam
Double check when u remove the paper it may still have some left
Need to know the exact error
Thanks
Jaywizz
Oct 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
Ben Johnson
