This problem should be removed because:
Problem with Toshiba Satellite M45-S165 (PSM43U00S00F) PC Notebook
I keep getting a page_ fault_ in_ nonpaged_ area error message
My Toshiba Satellite M45 notebook starts intermittenly. Mostly I get an error message or it freezes at the title page. It says if problem continue I should disable or remove recently installed soft/hardware,disable bios memory option such as caching or shadowing. Then it does a dump of physical memory. What does all of this mean? Where do I start? Do I need a new HDD?
Solutions (1)
This could be a software and not a CMOS problem.
First format that HDD, take it off if you want to backup and format it if it has bad sectors then you need a new disk, as for the boot you need to restore defaults on the BIOS menu F2 or F12 should get you there.
After that problem should be solved, worst case scenario you need a new HDD, but it's quite easy to replace and in some cases you even haev a port with two screws with direct access.
Blue Screen of Death
Can't get to anything outside of setup. Safe Mode won't work. Type in the XP password and get the following blue screen. A problem...
BSOD
Getting the following BSOD. Haven't installed any new hardware or software. Screen shows up mostly during startup, and when coming...
bluescreen after audio/video freeze
I haved an Acer Aspire One A0150. Often when I watch videos, listen to music, or go to websites that open with music/videos, I get a buzzing...
my leptop acer 4720zg physical dumping error
my leptop acer 4720 physical dumping error problem please you solve
Add Your Solution
i don't know where the CR2025 3 volt battery
i don't know where the CR2025 3 volt battery is
what would cause to quit after sitting for five
what would cause to quit after sitting for five mins the car will start and run for three mins and then stop
i cant see my mesages tht i sent to yahoo mesenger
i cant see my mesages tht i sent to yahoo mesenger and also replies are not shown
My Toshiba Satellite M45-S165 does
My Toshiba Satellite M45-S165 does not power on at all. Tested AC adapter on another Toshiba and it is fine. Tested wall...
See all Toshiba Satellite M45-S165 (PSM43U00S00F) PC Problems
Fix-O-Meter
102
102 people viewed this problem
- 0 people are following this problem. Be the first!
Top Toshiba PC Laptop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
