Question about Kenmore Washing Machines
Slugish spinning or no spin. Have had burning odor recently.
Could it be the clutch burned out? can i replace it myself?
  • 2 more comments
  • pyosh Feb 25, 2009
    Thanks for advice,but coupling has been replaced and problem still continued with lazy spinning.
    Thank you Guru. I will order a clutch and install it and see if it fixes the problem. Should I also replace the basket drive while I am at it?
    What should I be looking for on the cam ? Ware and cracks? Thanks for your help Guru
  • pyosh Feb 26, 2009
    Should I put some type of lubrication on the spin tube. If yes what type of grease and where can I get it? Thanks Guru
  • Kenmore Master
  • 3,361 Answers
If this is a top load machine you will need to replace the direct drive coupling on the motor.
Posted on Feb 25, 2009
  • 3 more comments
  • steve
    steve Feb 25, 2009
    Yes, the clutch would be the next suspect part.
  • steve
    steve Feb 25, 2009
    The basket drive should be fine.
  • steve
    steve Feb 25, 2009
    Be sure and check the brake cam when you pull the clutch.
  • steve
    steve Feb 25, 2009
    Broken tips that insert into the cam holes.
    You will know it when you see it.
  • steve
    steve Feb 26, 2009
    No grease.
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
Whirlpool washer will not spin
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Aug 19, 2014 | Whirlpool Washing Machines
Clutch engages but spins car wont move
Clutch needs replacement, haven't you smelled a weird smell lately? That would have been the clutch plate over heating and burning, hence the words,..Burned out clutch
Mar 04, 2013 | 1996 Chevrolet Cavalier
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Spin cycle won't spin. Burning smell. How do I
Remove the back -- you'll see the screws to do this. Sounds like the belt or the clutch is slipping and overheating.
Charlie
Aug 25, 2009 | Washing Machines
GE Washer does not reach full spin speed...stops abruptly
the motor does run right. the belt could be worn. or the clutch at the bottom of the motor check that.
Oct 09, 2008 | Washing Machines
Washing machine has burning odor
smell usually come from motor over worked, possibly under powered( check to make sure you have a110 volt, supply and not perhaps 100, possible bad start capacitor eminating small as well, its mounted either to the motor itself or on the back wall just below the water valve assy
Apr 21, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
