Question about Plantronics Explorer 330 Headset
Bluetooth Manual I want plantronics 510s manual...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 90 Answers
Can you supply a user manual for a Plantronics 500a system.
The 500A is part of the Plantronics 510S system. This link will take you to the Plantronics 510S User's Guide, which has the information you need.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager 500A Headset
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The headset will not charge from the base unit
It maybe that you need a new charger for your base. If your base is messed up there is no replacement for that. I know you can purchase other product for the base but not the base itself.
Here is a link to the Plantronics 510S Headset.
Mar 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have half a dozen plantronics voyager 500a units, with HL10 headset lifters and 510 bluetooth headsets that do not work. All of these came from the Voyager 510s packs some time ago (with a different...
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
Jan 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
500a will not pair with cell phone. my phone will pair with another bluetooth device so my phone is not the problem. I just got this 500a --- is there any special thing I need to do to pair it with my...
The Voyager 510 headset that's used with the 500a is compatible with most mobile phones. The link below has information that can be of benefit to you, especially page 5 (powering the headset on / off to reset) and page 6 (pairing).
Plantronics Voyager 510S User's Guide
Dec 23, 2010 | Plantronics Voyager 500A Deskphone Adapter...
I've plugged everything in, no signal on headset...what could be the problem?
Make sure that the Plantronics Voyager 510S / 500A headset is powered on (remember that it has an individual power button on the actual headset), and that it is paired up to the 500A base unit. Below is a link for the user guide.
Plantronics Voyager 510S/500A User's Guide
Oct 27, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Base unit won't work. Won't answer phone. Blue light is out and pressing switch doesn't get a response.
You want to make sure you have the approved Plantronics AC adapter, and it's plugged into a wall outlet, and connected securely to your base. If the lights don't come on like they should, carefully follow the compatibility and pairing instructions in the manual (see link below) and check to see how the base responds. If you're still having problems, then in the words of Doctor McCoy: "He's dead Jim."
Sep 10, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Have a 500 plantronics wireless headset/base, which are connected to either a meridian 2616 or 3903/04 and not able to get the dial tone on the headset (all cables are connected / move frecuency in the...
The Plantronics 500A base should be plugged into the handset receiver jack on the phone, not the headset jack. It could be that the headset needs to be re-paired to the base unit, or the lifter is worn out (if using one). If you manually remove the handset receiver from the phone, and you power on and activate the headset, does sound come through ? If so, it may be the lifter. Here is a link for the 510S / 500A user guide to troubleshoot, and also a link for the pairing instructions.
Plantronics Voyager 510S Pairing Guide
Aug 01, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics Explorer  330 Headset Logo
163 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
