Question about Kodak i260 Duplex Color Scanner
Tdd: 89 sense 05 03 00 text command failed check error log at (i 260 scanner )
  • 3 Answers
This sounds like a sensor issue, try cleaning the sensors, DO NOT use compressed air. Also try recalibrating the scanner. If all fails it may be a bad sensor, call kodak 800-822-1414 and they should be able to assist you.
Posted on Sep 15, 2011
Tdd: 1
Check the white patches on the underside of the Image guides make sure they havent been damaged or are dirty can also get the error if the guides are badly scratched
Jul 02, 2014 | Kodak i1440 Pass-Through Scanner
The scutum50 NDIS protocol driver service failed to start due to the following error: The system cannot find the file specified.
1. add /BOOTLOG flag to your C:\boot.ini to get a startup log in %SystemRoot%\NTBTlog.txt 2. check %SystemRoot%\NTBTlog.txt for driver errors 3. run from a command prompt sc queryex type= all state= all bufsize= 30000 > services.log 4. check services.log for the scutum service 5. evtl. unregister the scutum service with sc del Scutum50
Mar 08, 2013 | Computers & Internet
There is an error in connect...........
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
Jan 01, 2011 | Computers & Internet
C:\Program Files (x86)\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe The application has failed to start because its side-by-side configuration is in correct. Please see the event log or use...
Hello, I have Toshiba Satellite L675 Model lap top. My web camera failed to initialize the application. The error message said check your camera device and restart your computer or application again. But it is not still functional. My question is Is the model built web camera? how can I check the device? how Can I solve the problem to be my web camera functional? Thank you for help
Aug 02, 2010 | Computers & Internet
TI 89 when solving equations or integrating a message appears:
With the ALPHA keyboard, Type in the NewProb command and press ]ENTER] It resets the one-letter variables to their default status.
Alternatively, you can use the CATALOG of commands to launch the NewProb command.
Another way is
In HOME directory, press the [2nd][F1] to activate the F6 key. In the menu list, press 1:Clear a-z and ]ENTER].
If you have to use the variable x multiplied by a function (sin, cos, tan, log, etc) do not used implied multiplication: enter the [*] explicitly.
Apr 14, 2010 | Texas Instruments TI-89 Calculator
ERROR MESSAGE - COMMAND FAILED CHECK LOG (-4761)
I turned off the scanner at the mains and it reset itself.
Thank you anyway
Oct 01, 2009 | Kodak I260 Captiva IA-Express Path-Through...
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
My scanner i260 do not scan properly, it present a distortion in the image, Could you help me?
Thanks a lot
Mar 03, 2009 | Kodak i260 Duplex Color Scanner
1,097 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
