Question about Intel D945GNTLKR Motherboard
Want to replace intel D945 GNTLKR because of damage by which ?
Due to power failure repeatedly my pc motherboard damaged and want to replace it.But I do not know its equivalent.
    President:
  • 1,073 Answers
Hi!
Well, i will give you some recomendation, but this is only 4, there are about a couple of 100 more mobos similiar as the one you have so you can use all the hardware from your old mobo.
Here are 4 good ones and not to expensive:
ASUS P5B SE
ASUS P5K PRO
GIGABYTEGA-81945PLG
MSI P35 NEO-F
All of them with socket 775, all of them takes the memosticks you have on the old one, all of them with Pci-express slots and all of them with sata connections.
I hope this helps you on the way to find a good mobo
Good luck to you
Please take a moment and rate my help for you
Nic
Posted on Feb 25, 2009
  • 685 Answers
You can most likely get the same motherboard off ebay for a reasonable price
Overheating and shut down d915grv
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 27, 2013 | Intel D915GAV Motherboard
I need to replace my Intel D945GTP Motherboard. Will any board marked D945GTPxx work? I see several varieties and I'm not sure if they are interchangeable. Thanks.
Intel D945 GTP is a motherboard designed by Intel however there are other manufacturers like Gigabyte, MSI etc that also has the same design such as that of Intel D945 GTP which more or less is compatible. As far as buying a new motherboard is concerned I would suggest you should look at the make/model of the processer that you are using currently and also check the type of ram that you have like DDR or DDR2 etc and check for motherboards that can work with what you already have along with better on-board graphics than Intel D945 in case if you are into playing games.
Jul 30, 2011 | Intel D945GTP Motherboard
Due to power variation my display suddenly goes blank, then i powered off my system. again restarting there is no display on monitor only monitor light blinks.cpu is working properly ,hard disk, ram ,heat...
if it is an on board video sound like it got damaged by power failure,try adding on a video board and disable on board video in bios,make sure you have an avalible slot to add board
Feb 02, 2011 | Intel Motherboard
Is there any vga / sound driver for intel D845 motherboard for windows 7 or windows 7 is useless for these motherboards? Shahid
D945 graphics controller will do
Need to install from Device Manager --> Display Drivers -->Browse form computer and then choose the path of D945 graphics setup folder
May 14, 2010 | Intel 845GE Motherboard
I want intel p 4 d945-gccr drivers
i want intel motherboard d945 driver for free download pls make a way
Mar 18, 2009 | Computers & Internet
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Hanging problum D945 GCCR
hi im josh in cebu phils.may i help ypu? Friend if your pc hangs up. most problem of the pc hangs when the power supply has not enough current to support the motherboard.try not to use a lot of devices or replace your pwer supply with stronger one. or try to check also your memory if it is seated properly in the memory bank. good luck
Feb 20, 2009 | Intel D865GBF Motherboard
Power failure
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
100
Oct 31, 2008 | Intel D845GVSR Motherboard
Gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Aug 18, 2008 | Gateway 505GR PC Desktop
Motherboard D945GCL Problem
Your OS Might have corupted, you can try reinstalling the OS.
Jan 02, 2008 | Intel D945GCL Motherboard
Intel D945GNTLKR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
