Question about APC (BE500U-WEB) (BE500UWEB) UPS System
UPS Switching off while working
Respected Sir,
Our APC Back-UPS ES 500 - switches off abruptly while working on the computer.
The red light blinks.
What is the solution. Kindly please reply immediately.
Kumar ( Jayanagar Bangalore )
  • 33 Answers
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 25, 2009
  • 39 Answers
So it sounds like your system won't hold power while running on battery power is that right? then you probably need a replacement. Here is an easy way to get a replacement http://www.batteryinternational.com/apc-backups-es-be500u-ups-battery-ups-batteries-f2.html That should be just the batter you need. Hope that helps
Posted on Jul 08, 2009
APC BACK- UPS ES 500 IS NOT SWITCHING ON !
Quite likely that the battery has died in it .they do not like being put to bed for extended periods of time .
Aug 31, 2015 | APC Computers & Internet
Blinking red and green lights
Check battery and charging voltages. APC says 90% of faults are a dead battery. My experience also
Oct 15, 2014 | APC Products - APC - Back-UPS ES 750...
APC ES750 buzzer
Need new batteries probably as batteries may have developed high internal resistance.
Test the batteries one at a time whether they would light up a car headlamp bulb.
Apr 18, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
After i switch on the ups there are continuous beeps with red light instead of the normal green. if i continue to use the beeping stops after sometime but the red light persists. But then again the beeping...
ups with 300 watts can only back up 1 computer, though it can handle 2 computers but not too long. your ups battery life span are good only for 2 to 3 years. for battery replacement you can visit the nearest service center and ask for battery replacement. it will not cost you much.
Feb 10, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Apr 29, 2010 | APC Smart-UPS 1000VA UPS System
APC Back-UPS ES 350 - when powered on has a blinking green light Is this normal
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here: http://www.batteryinternational.com/apc-backups-es-be350u-ups-battery-ups-batteries-f1.html
Oct 06, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
My 500-A Ups is making Buzzing sound.
APC 500VA ups meant for 1 Desktop and one montiro it will have battery backup for 10 to 15 minutes for the above.
Normally, You should make the raw power connected to UPS should be always ON.
The power cables of CPU and Monitor is connected with UPS. When not in use, please press the Button available on the UPS.
The UPS Life is normally 2 to 3 Years only. Now you are getting the sound and Red Light will always blink and not allow to use the system.
Better replace the 12 Vols battery to get some more life for the UPS.
And check for any loose connection of the power cables connected with Raw Power and UPS System.
Jul 19, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC (BE500U-WEB) (BE500UWEB) UPS System Logo
417 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
