Question about Acer Aspire AM5641-U5520A PC Desktop
Acer desktop auto restart when memory usage is greater than 2.18G
My acer desktop has 3 G memory. When I launch several applications and the memory usage is greater than ~2.18G. The desktop auto restar. What's the problem? how to fix it? thanks.
    Scholar:
  • 77 Answers
I sense heating issue!! Lower down the FSB i notch from the bios and it should stop conking out.
You can also try checking the event log in event viewer (eventvwr.msc in run command) and see what the last instance was before the pc rebooted. If its a driver update it.
Try increasing the virtual memory or paging file.
If you need steps let me know.
I hope this helps!
Rate if its a fix
Thanks
Keshey
Posted on Feb 25, 2009
How do I enter the recovery (Acer Partition) of Emachine et1810-01
Hi
The factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
1.Click Start, and then All Programs
2.Click Acer, and then Acer eRecovery Management
3.You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
4.In the next window on the left toolbar, select Restore.
5.Choose Reinstall Drivers or Applications
6.Choose Contents
7.Choose the driver or application you wish to install
8.On the right, click the Install link and follow the prompts.
9.The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from our Acer Recovery Media Order Form.
Please take time to rate me
Sep 24, 2011 | eMachines ET1810-01 PC Desktop
Why is my acer hard drive divided into two(2) seperate drives with 36 GB in each drive
One half of the disk contains the program application while resourcefulness is attained from the remaining spaces. Usually the computers disk spaces allows only least application programing from the manufacturer, where a greater faction of the sapces are memory spaces with capacitis to display prorgams with several codes.The computer adjust according to what is requested either of memory, storage spaces.
Feb 14, 2011 | Acer (91.AB033.041) 73 GB Hard Drive
The volume keys on my Acer 5738Z have stopped working.after installing window 7 how to solve it
You will need to download the launch manger application to make the volume keys work. Click on the link i have provided below and scroll down to near the bottom of the page. On the left hand side look for launch manager and click on the orange icon next to it. Once downloaded install the application and the volume problem should be resolved once you have restarted the laptop. Link below >>>>>
http://www.laptop-software.com/acer-software/acer-aspire-57385738g5738z5738zg-drivers/
Regards.
Oct 20, 2010 | Computers & Internet
The sound scroller on the left has frozen, i have made sure hold is not on but it still wont move.
what you need to do is click on start then right click on computer and select manage once the window opens select device manager and a list will come up on the main screen. Go down the list and expand the keyboards selection and there should be a listing called launch manager. Double click on it and on the properties window click on drivers and it will give you several options, click on uninstall and go through the list if it asks you if you want to uninstall click yes. now that its uninstalled go to support.acer.com select notebook then aspire and finally 6920. then under the list you can select your operating system, be sure to pick your operating system e.g. windows vista home premium x32. then click on application scroll down and download launch manager. Restart your computer install launch manager and restart again. Congrats your media center counsel should work!
Feb 14, 2010 | Acer Aspire 6920 Notebook PC
Acer Laptop 7720G is getting crashes and auto restart
Try Advanced system care . You can download a free version that works well . I would also recommend you download Malaware Anti-Malwarebytes
Apr 12, 2009 | Acer Aspire 7720 Notebook
Installing acer launch tools in aspire 5920g model laptop
you need new installer windows and you need manual install you're recovery programs is corrupted..try to use new installer...
Thank You
Apr 03, 2009 | Acer Aspire 5920-6335 Laptop
Orbicam freezing in Skype
1. Check if your computer has enough memory available. Open task manager, select performance tab. Check the green bar on the bottom then copare memory usage to the total of your Physical memory. If your usage is greater then physical memory then upgrade memory on your laptop.
2. Unistall your Skype application and reinstall it. Do the same for your Webcam.
Good luck.
Jun 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
Acer Aspire AM5641-U5520A PC Desktop Logo
267 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
