Muratec MFX-1430D Copier Logo
A
Anonymous Posted on Mar 14, 2013
Cannot locate mail server error message - Muratec MFX-1430D Copier
Can't access my e-mail. get 404 not found message. required url/neo/launch not found on this server.
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested. A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future.
Oct 11, 2011 • Yahoo Mail
tip
Bounced email
In computer jargon, a bounced <a href="http://www.webopedia.com/TERM/E/e_mail.html">e-mail</a> is one that never arrives in the recipient's inbox and is sent back, or bounced back, to the sender with an error message that indicates to the sender that the e-mail was never successfully transmitted. But what happens when someone sends an e-mail out into cyberspace, and why do e-mails sometimes bounce back?<br /> When a <a href="http://www.webopedia.com/TERM/U/user.html">user</a> attempts to send an e-mail, he is telling his e-mail system to look for the <a href="http://www.webopedia.com/TERM/D/domain.html">domain</a> of the recipient (for example, webopedia.com) and the domain's mail <a href="http://www.webopedia.com/TERM/S/server.html">server</a>. Once the e-mail system makes contact with the recipient's mail server, the mail server looks at the message to determine if it will let the message pass through the server. If the recipient's server has predetermined that it is not accepting e-mails from the sender's address (for example, if it has blocked the address for <a href="http://www.webopedia.com/TERM/S/spam.html">anti-spamming</a> purposes), the server will reject the message and it will subsequently bounce back to the sender. The message will also bounce back to the server if the mail server on the recipient's end is busy and cannot handle the request at that time. When an e-mail is returned to the sender without being accepted by the recipient's mail server, this is called a <a href="http://www.webopedia.com/TERM/H/hard_bounce.html">hard bounce</a>.
on Dec 22, 2010 • Computers & Internet
2helpful
Always cannot find the srever at yahoomail
This may be due to a number of reasons:
(a) if yahoo mail is your home page & you're using wi-fi, then your browser (Internet Explorer? Safari? Mozilla Firefox?) may return the error message "Cannot find Server" when the wi-fi link has poor (or no) connectivity.
(b) the Yahoo mail server may actually be down
(c) there may be a typo in the URL (universal resource locator) you're using - even a single mistaken character will cause this error.
(d) there may be a cut in the internet between your computer
and the Yahoo mail server, but the nameserver still has the server's IP address in its table.
(e) about 1000 other reasons.
The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was '[email protected]'. Subject '', Account: 'pop.attyahoo.com', Server:...
One problem is that the incoming (POP) mail server shown in the error message appears to be incorrect. The server address should be "pop.att.yahoo.com" (with a period between "att" and "yahoo"). The incorrect mail server address may interfere with authentication of the sender's email address, which is needed before the outgoing message is sent.
The "530 authentication" message indicates your outgoing (SMTP) server likely requires "server authentication". Also, the "Port 25" message indicates your email program is currently trying to send via Port 25, with no SSL; but Ameritech/Yahoo accounts appears to use Port 465 with SSL enabled.
See more on sever settings for "ameritech.net" users:
http://www.dslreports.com/faq/5535
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61941/~/i886---at%26t,-bellsouth,-sbcglobal,-ameritech-email-settings
I would suggest you check the settings for your Ameritech email account in your email program. You may need to correct several settings. The steps to access account settings are somewhat different for various email programs (Outlook, Windows Live Mail, Thunderbird, etc.). You should be able to find guidance in the "help" section of your email program.
3helpful
3answers
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
2answers
Mail sending problem in outlook express 2003
Tried to take backup of messages was not able to copy the dbx files
- Rename folders.dbx
- Was able to send/receive messages without any error
May not able to retreive some messages in sent items, deleted items folder
>lets create new identiy
http://support.microsoft.com/kb/209169
1helpful
"Can't connect to email server, make sure you have an Internet connection"
Whenever a mail server is unable to process an e-mail request, the e-mail fails and the software displays one of the following error messages: Can't connect to email server Progress bar stuck at 0% To resolve this problem go to http://www.kodak.com/go/itg
Top Muratec Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
