Question about Konica Minolta DiALTA Di200 Copier
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
I CHECK ALL THE TONER HOPPER UNIT .I CAN FIND OUT THAT IS TONER MOTOR VOLTAGE SUPPLY IS NO CURRENT . I HAVE NO SERVICE HAND BOOK
  • 145 Answers
If it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Posted on Feb 28, 2009
WHAT'S YOUR PROBLEM CODE C-004F
Posted on Oct 31, 2012
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
How to remove the Minolta Di 450 code 13 and 14
Posted on Mar 03, 2014
    New Friend:
C0039
Posted on Apr 24, 2013
Konica minolta 1050e error code SC23-13
Code
SC23-13
Description
Air separation motor (M10) rotation abnormality. Since an error is detected when the M10 turn ON, turn it OFF. An error is still detected when turn it ON again.
Causes
Air separation motor (M10) Air motor encoder sensor (PS30) Resetting of the intermediate toner hopper section
Remedy
The main body stops immediately to turn OFF the RL1 (main).
Nov 22, 2017 | Konica Minolta Office Equipment & Supplies
Solution for konica minolta 250 malfuncion detected c2557
C2557 for Toner Density Control abnormality in Developer.
Try in this sequence..
1-Check Toner, if Empty, Reset code and install new toner bottle.
2- if not from above, Then replace Developer and Developing Unit.
3-if Not, then check Hopper Unit, Clean Sensor and Solenoid.
Jul 19, 2017 | Konica Minolta Office Equipment & Supplies
Bizhub 162 posting error code c0070
Toner Hopper motor error, check the drive of Toner motor.
Jul 26, 2016 | Konica Minolta bizhub Office Equipment &...
C0070 in minolta211 copier
The Toner Bottle Home Position Sensor (PC7) output a HIGH signal for a continuous 3.5 sec. period while the Toner Bottle is turning.
The Toner Bottle Home Position Sensor (PC7) output a LOW signal for a continuous 2- sec. period while the Toner Bottle is turning.
Check Motor (M6), Sensor (PC7), Master board (PWB-A) & Power supply unit (PU1).
Oct 21, 2014 | Konica Minolta bizhub Office Equipment &...
Where is the ATDC sensor
If you replaced the developer unit then you already replaced the ATDC sensor. using third party toner or KMBS? if so use only KMBS
Jul 25, 2014 | Konica Minolta Bizhub C360...
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Error code c0070 konica minolta copier service code c0070
Sir/Mam
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Konica Minolta DiALTA Di200 Copier Logo
2,130 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
