Question about Microwave Ovens
Need microwave glass door replacement
I broke the microwave glass door while cleaning it and I need a replacement immediately. Whirlpool model MH6140XKQ white, part # W10206726. I've ordered this from 2 other websites but with the first one they had no idea when it will be delivered and with the second one (SearsPartsDirect.com) I've been waiting for 5 weeks now and just today they told me that estimated delivery will be in April. This is a really old model (2001) and most sites will say that this is a backordered item.
I am just renting my apartment and it will cost too much to replace the whole microwave. Does anybody know where I can find this ready to be shipped? Or can I use a glass door with the same dimensions from a different manufacturer (since all glass doors are basically the same)? Or is there like a generic glass door that can be purchased? Would appreciate any references. Thanks!
  • snorf Feb 25, 2009
    Thanks jyackle5, I will contact these stores to confirm the availability. I've tried other sites that showed the item is available but after checking with their customer support the item is on backorder or the like. Seems like they don't update their websites as often as needed as in the case of the 2 sites I ordered from more than a month ago.
  • 8,197 Answers
Http://www.mdappliance.com/WPL-W10206726.html
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=1946925
Here are 2 sites that have it. The second site has in stock in alabama ready to ship.
Good Luck and Please Rate FixYa!
Posted on Feb 25, 2009
  • 4 Answers
I know it have been long...did u get the door? I have one in hand....
Posted on Feb 07, 2011
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
How do u clean the forr inside glass behind the metal screen? whirlpool microwave model MH61130XEQ1
extremely carefully, the door skin is going to have to come off, some are so difficult to do, most people call a service technician because they break the door, and usually meed to replace skin or the entire door
Feb 24, 2011 | Microwave Ovens
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
The tempered glass on the outside of my microwave oven broke. Can I replace this with plexiglass and keep the microwaves from leaking?
Pliglas does not inhibit microwaves. Generally, even the glass door isn't protection either. A special film, usually a polymer, is applied to the inside of the glass. The 'film' looks like a black or gray 'screen' with little holes in it.
Answer: DON'T DO IT!
Feb 06, 2010 | Whirlpool GH7145XF Microwave Oven
The insulation around the inside of the microwave oven door has fallen down. New Whirlpool over the oven microwave. I can see the insulation through the glass. Tried to lightly tap the door to make it fall...
I called Whirlpool Corp and told them about the problem. They are sending a factory authorized repairman immediately to repair or replace the door. Thanks to FixYa, I found a solution!
Respectfully,
Jim
Nov 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
repairclinic.com
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Clean between mesh and glass on microwave door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2008 | Whirlpool MH7140XF Microwave Oven
Can't clean microwave oven door
you can change this part easily... if you want a fresh look, or using a degreaser that is available in home depot...
cheers
Nov 24, 2008 | Microwave Ovens
Whirlpool MH7140XFQ
It's most likely caulk. It can usually be sliced with a razor blade.
Sep 21, 2008 | Whirlpool MH7155XM Microwave Oven
Microwave Ovens Logo
319 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
