Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
My keyboard and touch pad isnt working on my laptop. i plugged a mouse in my usb and its moving.. but my keypad isnt working... my caps lock is lit up..i tried pressing it to turn it off but it didnt work... is my keyboard frozen of locked?? please help... jay
    Scholar:
  • 180 Answers
If your operating system is Xp / vista reimage your unit by hit F11 on started up & Hp splash screen - select advanced - select full destructive recovery - you have corrupted your device controler for human interface devices - like your k/board & mouse - there is no way to reinstall the required dll's so full recovery is required.
Posted on Mar 08, 2009
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
Mouse pad isnt working??? I just got my ASUS laptop today NEW. when I boot it up mouse touch pad won't move cursor to log in ect.
r u in DOS mode ? mouse wont work in DOS mode..
if u got the Win Logon screen and mouse does nto work....
Shutdown the machine....
and send it back for a full refund or replacemnet....
u say it's new....so dont fiddle with it...
if u have an external USB/PS2 mouse u can connect it to the USB port or the PS2 keyboard/mouse port and check if the machine is working....
i suggest u send it back or take it to the shop where u got it...
Dec 25, 2009 | Computers & Internet
When I hit y or w the cursor jumps to another part of the email usually where the pointer is sitting. Laptop computer.
The problem isnt the Y or W key. It's the position of your hand on the keyboard. Try using a wireless mouse instead of the touchpad. Then press your Function F5 (or whichever one turns off the mouse pad) and test it out. You're touching the mouse pad while you type. I do this all the time and it's very frustrating. I just went out and got a USB wireless mouse... It works great. Have fun!
Oct 19, 2009 | ASUS A6U Notebook
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Aug 13, 2009 | Belkin F5L017 Mouse
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
