Question about Riso Office Equipment & Supplies
Riso RA5900 ink problems
I keep getting a error message that the ink needs to be replaced and the ink tube is new. the red light on the light panel will not turn off!
Had this prob with a RA4050. Took out the ink tube, used a pencil to push the base up the ink tube till it appeared at the top. Reloaded ink tube and was resolved. Maybe air bubble in ink tube?
Posted on Feb 27, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Hello I have an old model riso ra5900. I have changed the drum but it won't lock back into position? Any ideas?
The cartridge might not be supported by your printer. Look on the old cartridge and compare with your new one, if there's a change in the construction.
Feb 16, 2015 | Office Equipment & Supplies
D04-561 riso error code
It is not recognizing your ink cartridge. Try another tube of ink. Otherwise you may need to reprogram the drum.
PrntNow.com
Apr 19, 2013 | Riso RZ220 Duplicator
How can I fix an error code 'c01-563' on Riso RZ370
Changing the ink tube or the RFID chip on the ink tube may solve your problem.
PrntNow.com
Apr 12, 2013 | Office Equipment & Supplies
I have a Risograph RZ390ui. About a week ago, with my green drum installed, it began telling me to replace the ink cartridge, even though it wasnt empty. Now I cannot get that drum to work. Now, the same...
It is possible the ink with in the tube has become unprimed, example not push up to the exit point so its drawing air and never gets caught up before the error occurs. Be careful by pushing plunger inside tube due to the ink becoming "separated" from the oil and be to "liquid" for the ink pump to do its job..If it pours out like wine its to old sry.Should be as thick as toothpaste.
Sep 14, 2011 | Riso RZ390 Duplicator
Error Code H101 on my EZ220U RISO--what does this mean?
You will need to go into service mode, to input the value on the machine for the ink color the value is 1-black or 2-color.
Hope helps.
Jun 02, 2011 | Riso Office Equipment & Supplies
Riso rz230 aw has error codes d-04 -534
riso mz series has error codes D04-534 and D44-538
Jan 06, 2010 | Riso RZ220 Duplicator
Paper not feeding. The drum is spinning LCD screen read idling
If your Riso is idling it is probably due to it trying to get ink into the drum.
Let it finish the idling may take 3 to 5 min, then make sure there is ink up to the spout of ink tube or replace ink tube.
If you press the astrex button it can give code which you can look up in the book.please tell us the model of riso.
Apr 05, 2009 | Riso RZ220 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
I keep getting a printhead error....I have replaced the printhead with the canon spec printhead and I keep getting the same error message.....any thoughts?thanks,Parker
Check the wiring assemble connecting the printhead to the printer and where the wiring connects to the printer. Anything loose here would prevent the unit from correctly reading the sensors on the printhead. Just a thought.
Nov 03, 2007 | Canon imagePROGRAF W6200 InkJet Printer
198 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
