Back to:
Tags:
Nikon Speedlight SB-16A TTL Flash
Nikon F3 / SB-16A flash problem
By man1 - usenet poster
Some of the frames on my last two rolls of film have a problem. Half the
frame is exposed fine, and half is overexposed to the point where the prints
on that half are almost (but not completely) black. It only happens with
shots using the flash, but not all of them. Even when taking flash shots in
succession, one may be fine, but the next one isn't. The dark band is
vertical and covers just less than half of the left part of the frame.
I bought the flash just under a year ago from B&H (I actually bought it as an
SB-16B to replace an older SB-16A, and gave the old flash and new base to my
sig other to use with an N2000.) I will of course replace the camera
battery and clean the flash contacts, but has anyone out there seen anything
like this before?
Thanks! -- ric
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Grant
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Probably got your darkroom head on. You'd be surprised at the number of
courses that will teach you how to correct bad exposure in the darkroom
months before they teach how to actually expose a film properly...
Martin
*insert wit here*
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Nikon F3 / SB-16A flash problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Beresford
Rating: 0%, 0 votes
Yes you're quite right, what the hell was I thinking?
Hmm, I also thought it seemed like a flash sync problem, and the camera
is supposed to automatically set the shutter speed to 80 when the flash is
attached. I guess I could manually set the shutter to "X" to see if that
corrects the problem. Thanks for the suggestion.
Thank You!
Solution #3
Not Rated (0)
Putty
Rating: 0%, 0 votes
Are you shooting faster than the sync speed (1/80? 1/125?) of the camera?
The F3 has a horizontal travel shutter (explaining the half frame)
Alan
Thank You!
Solution #4
Not Rated (0)
Putty
Rating: 0%, 0 votes
If it's of any help in your troubleshooting, that'd be "underexposed."
The symptom is consistent with the shutter operating faster than the F3's
maximum flash sync speed, 1/80, if memory serves.
John Miller
We are what we pretend to be.
-Kurt Vonnegut, Jr.
Thank You!
Can you Help with these Flashes problems?
Flashes
Ringflash will not fire. Contacts are clean. New...
Flashes
Cannot get my speed lites 550EXII as a master unit and my...
Flashes
le detecteur de mouvement ne foction plus
Flashes
Hello I own a Panasonic Lumix DMC FZ50 camera and would...
Flashes
I have a two month old Sandisk2GB MP3 player Which has...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
