Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore refrigerator condenser fan not running. It does not appear to have current to it. Is there a thermal switch that turns the fan on or is it supposed to come on with the compresser?
  • 1 more comment
  • terryb99 Feb 26, 2009
    appldoctom, thanks for your reply. I have fixed the problem by replacing the condenser fan motor. Apparently the motor is controlled by a thermal switch because the compressor was running and I wasn't getting voltage to the motor. I tested the motor by itself and found it to be bad. Once the new motor was installed the over heating problem went away and the new motor cycles on and off normally.
    Thanks again for your help!
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    good job!i have fixed oh about 1,500 refers out of the 15,000 service calls ive done and haven't seen a thermal switch on an condenser fan motor,but who knows the manufacturers are doing new things all the time. God bless ,tom
  • Thomas Malailua
    the term would be voltage.current is how much a power consuming part is using.if you have no voltage[120 volts]you would have to look at your refer wiring diagram,but the voltage usualy comes from a compressor curcit,because when the compressor starts so does the condenser fan motor.....................now if your talking about the fan in the frezer ,its called the evaporator fan motor,and it gets 120 volts also,but in some brands[amana]one side of its power does come thru the term thermostat or as you called it a thermoal switch
I don't get 120 volts to my evaporater fan motor. What part do i need to check or replace to get the evaporater motor to work? I have replaced the motor, but it still doent come on.
Posted on Jun 16, 2009
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
Dec 03, 2017 | Kenmore Refrigerators
Kenmore Elite fridge cools but we noticed the compressor and fan never turn off. Compressor is very hot to touch. Do we need to replace compressor or a relay switch or ...? Thoughts/suggestions?
Newer refrig. Run almost continuous but you could try cleaning the condenser coils, located on back with vacuum and brush also place thermometers in freezer and mid level refrigerator, freezer should run 0 to -8 F and refrigerator 34-37 F. If much lower adj. thermostat up.
Sep 16, 2017 | Kenmore Refrigerators
Condenser fan problem on Kitchenaide Refrigerator - kscs23inss01
What you are going to find is this... Your COILS under the Plastic are Condensating and FREEZING and then this is what is causing the On /Off of the Temp. You have to DEFROST the COILS (Under the Plastic) and remove ALL the ice and Moisture. Once you get this problem resolved, it will work perfectly. This problem was caused by the Condenser Coils being Dirty and and the Switch on Top, Under the Plastic from being unable to work properly. This is a time consuming issue but easy to do. DO NOT SCRAP or BREAK the ICE after you take the Plastic off, use a hair dryer or Hot Water and make sure the Drain Tube is completely cleaned...
Mar 03, 2014 | KitchenAid Refrigerators
Kenmore electronic,frosts up and fan quits.every thing i cked is ok.
If the doors are sealing tightly then i sounds like a defrost heater/timer or bad high limit switch. Thaw the evaporator out. If the fan does not run at all within the first twenty mins then the poblem is in the fan motor or thermostat switch that contols the fan motor. Lastly if the coil is only freezing up partially then you have a refrigeration issue. Reguardless make sure you have cleaned the condenser area of lint and pet hair at least once every two years.
Nov 10, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
Kenmore side by side refrigerator. Condenser fan
i DONT HAVE A CONDENSER FAN FOR MY FRIDGEDAIRE SIDE BY SIDE REFRIGERATOR. I'm using a regular fan. How can i purchase one
Jun 03, 2010 | Whirlpool ED2FHSS Side by Side...
Kenmore elite refrigerator no longer cooling
Try moving it out so that you can get to the back of it. You have power as the lights work. Here are a couple of things to check. There is a fan motor with a blade on the shaft. Turn the temp. control down so unit will cycle on. See if this condenser fan motor is running. If not, it has burn out. If it is running, check to see if you can hear the compressor pot running, You will be able to hear it come on when you turn the control down to colder.Please don't turn the control up and down, as this will cause the compressor to short cycle and lock out on overload. Wait about 5 Min. between moving control knob. If compressor doesn't run, it could be the start relay, or you have lost the compressor. There are many things that can go wrong, but these are just a couple you can check out yourself. Condenser fan motor you can replace yourself. I hope this gives you a place to start.
Good Luck, Sincerely, shastakaker7
ps Always unplug unit before replacing any parts.
Oct 30, 2009 | Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
1,580 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
