Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
Refilling lexmark x5070 ink
I got a refilling kit and it will not read its in
I have this same printer. The print cartridges have chips in them that disable them after a certain amount of print jobs, even if there's still ink inside. You can not refill them. I will never buy another Lexmark, they are obviously a greedy company that cares little about their customers.
Posted on Mar 21, 2009
I just installed a Lexmark X5070 which was given to me second hand and worked for the people who gave it to me. It "acts" like it's printing, that is, the paper goes through the printer, but there is...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 05, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
After refill computer says no ink and i checked the ink is full how can i reset the computer to tell it is full
unfortunately you can not reset it. If you refilled your cartridge rather than replacing it then its very possible the print head on the cartridge is damged and no longer working. Its best to either refill a cartridge once or not at all. The print heads on the cartridge are not desinged for that type of use. If a replacement cartridge doesnt fix the problem then you probably have a bad print head inside the printer.
Nov 18, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Inkjet says empty after refill
It's possible the printer "remembers" the cartridge you refilled. Some printers have specific cartridge recognition built into them. It's to ensure you actually replace the cartridge instead of refilling it with ink which the printer manufacturers don't recommend. Apart from using a different cartridge, you can do a power reset (unplug the printer for 20 minutes) and attempt to use the same cartridge again.
Nov 10, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Refill lexmark z640 cartridge
You still can use the refill that in the kit as they all based on the same method, let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Sep 26, 2009 | Lexmark Z640 InkJet Printer
Problem with ink refills
Yes these two should work with your model. Here's also a link to the cartridges for this model for your reference.
http://www.lexmark.com/lexmark/product/home/999/0,6970,204816596_653293766_1113019367_en,00.html?tabId=7'
"Lexmark does NOT support the refilling of its ink cartridges.
Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the printhead.
Any damage to your printer caused by refilled ink cartridges may not be covered under your warranty."
Jun 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Help me
the older lexmark cartriges have a chip that will not let you refill but the newer ones don't have the chip. also if you wait until the cartrige is totally empty it will not work properly
Sep 28, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Low ink
Wow, nice "solution," Printech. That is BS. There has to be a way to trick this printer into using refilled ink. If not, why would they sell refilled ink kits for this printer? Cut the **** and give us a SOLUTION. I refuse to pay $30 for a "certified Lexmark" cartridge when I can spend $15 for a refilled one.
Sep 06, 2008 | Lexmark Z1420 Printer
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
213 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
