Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cannot Access USB
When I try to open the USB drive, i get a message box that says "Access Is Denied". It was working fine before.
  • 115 Answers
Maybe your usb files are corrupted ,do the quick format
start--------right click on computer then click on manage then device drivers ,see if usb drive right click then format
Posted on Feb 25, 2009
D: is not accessible Access is denied
Actually you do not have full access even though you are the administrator.
Right click D drive
Properties
Open security tab
Click on authenticated users, and click on edit
Check full control under allow.
Nov 17, 2015 | Iomega Select 1TB USB 20 Black External...
Usb drive access denied
did u uninstal drivers first?
might need to run as administrator.
let drivers search internet so it goes straight to windows. try windows update
Nov 29, 2017 | ZTE Computers & Internet
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Sep 06, 2013 | Computers & Internet
WDBAAF0010HBK-01 DRIVE ACCESS IS DENIED BY LAPTOP
you have to save the files using a computer with the same os that u origanlly and then format the drive on the windows seven computer then move the files back on to the drive
another thing to try is to try and update the drivers on your win. 7 computer
the last thing is you have lost all ur data and you should just reformat it
May 08, 2010 | Western Digital External USB 2.0 80 GB...
Acer Desktop USB & DVD Drive Access Denied
ok e lock is i think is a software of acer, you need to put the password of elock on your usb port, before u acess that.
Sep 08, 2009 | Acer Power 1000 PC Desktop
C drive access is denied
user login or administrator?
Aug 27, 2009 | Computers & Internet
PLz help to get access back for my external hard disk
iskh iskh...very pity man...simple problem...just used yor house key...just simple as that...
Feb 18, 2009 | Western Digital External USB 2.0 80 GB...
Cannot access any of the USB or DVD drives
Check under Device Manager in your PC properties, you may have "Enhanced USB" disabled.
Jan 24, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
125 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
