Question about Kenmore 24032\24036 Top Load Washer
Washer washes and wont spin clothes in either the wash or rinse cycle
  • civiccom Feb 25, 2009
    kenmore mod#417 44052400 side load. all wash and drain working normal but will not spin to dry out clothes in wash and or drain/spin cycle. check door switch, operation normal. can slide in a flat screw driver to opperate door switch. any help.....
  • 188 Answers
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Posted on Mar 02, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 1294 Answers
SOURCE: Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Posted on Apr 05, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
SOURCE: Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Posted on Jan 09, 2010
Whirlpool washer ties clothes in knots on spin cycle
Its the wash or rinse cycle that is tieing the clothes in knots not the spin cycle. Try putting less shirts in. It happens because of the agitation during the wash. Or pin the sleeves together.
Mar 09, 2015 | Whirlpool LSR5132PQ Top Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Hot point Washing Machine
LOTS OF VARIATIONS.  SOME W/MACHINES HAVE A SOAK BUTTON WHICH HAS TO BE DEACTIVATED TO ALLOW WASH CYCLE.   possibly wash winding defective.  could be loose connection at motor terminal as there are connections for spin and forward/reverse(wash cycle).if unit has element, select low temp and see if it washes.  need techi otherwise.
Oct 24, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
136 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
