Question about Denon AVR-1602 Receiver
Play phono - vinyl records
I am thinking about getting my vinyl records collection back to life again. how can i connect a record player to avr 1602. i understand there is no input connection for phono.
  • 4,234 Answers
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Dan
Posted on Feb 25, 2009
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Why can I not record to a CD from the "aux in" port?
Your question has not provided enough information. Are you trying to record vinyl onto a cd?
You cannot record onto a normal cd player. You need a cd burner(/recorder).
Vinyl turntables have a quieter output signal too so unless you have a device that has a phono (vinyl) input you will not be able to record your vinyl. If you have a laptop then the easiest way to record vinyl onto cd is to buy a soundcard that has phono input. You can then use free software (programme) like audacity to record your vinyl and covert it to a format (wav aiff or mp3) to burn to cd using iTunes or Windows Media player.
Sep 27, 2014 | Audio Players & Recorders
How do i record vinyl onto cd using rcd-w100
PLAY the record on a turntable that either HAS a PHONO preamp or through a PHONO preamp.
Sep 12, 2011 | Sony RCD-W500C 5-Disc CD Recorder
When recording vinyl to cd ..when i play the cd back i can hear the cd motor on the recording
Hmm, no products identified nor connections defined.
It is more likely you're recording the turntable motor than the CD motor. Are you passing the vinyl through a PHONO preamp as required?
Sep 01, 2011 | Audio Players & Recorders
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Denon Receiver AVR 1602 not playing Dolby Digital w/ Samsung BD
Dolby signals are passed via either an RF cable or optical link. Both the receiver and player need to have these switched on and that they are passing the correct signals. You clearly found the correct setting for the TV sound link. Now you just have to find the one for the DVD player.
Jun 02, 2017 | Denon AVR-3805 Receiver
Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Nov 21, 2008 | Denon AVR-1803 Receiver
Connecting speakers to amp
Your Amp will be having a pair of Phono / AUX input sockets at the rear. Connect the two Red and White cabbles from the Turntable to these sockets. I am unaware of what are Pilot Speakers. regular speakers have a dual colored pair of cables coming from them. they have to be connected to the speakers Connectors at the rear of the Amp. Play a Vinyl Record, select Phono on your AMP, and enjoy your music.
Sep 15, 2007 | Audio Players & Recorders
Denon AVR-1602 Receiver Logo
268 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
