Question about Creative Labs Zen MicroPhoto MP3 Player
Install Drivers i need the installation cdrom/drivers for the creative Zen MicroPhoto 8GB Model DAA-BA0009
  • Anonymous Apr 18, 2009
  • 371 Answers
You will find your drivers on the creative site
As part of our ongoing efforts to supportyou, Creative is happy to introduce the MP3 Player Recovery Tool, aprogram that resolves the majority of player problems quickly.
One click is all it takes to update yourplayer to the latest available firmware, and to give your player aclean bill of health.
BEFORE YOU START
  • Check that the MP3 Player Recovery Tool supports your player.
  • Ensure that you are using Windows XP® Service Pack 2 32-bit,Windows XP Professional x64 Edition or Windows Vista™ (32-bit or 64-bitversion).
  • Back up the contents of your player, if possible, as recoveringyour player may require it to be re-formatted, erasing all content.
  • Make sure your player battery is at least 50% charged.
  • Detailed usage instructions are available in our Knowledge Base.
    Click here if you require further information/assistance.
Posted on Apr 09, 2009
Creative zen microphoto 8gb stuck on locked. Tried taking battery out and pushing a pin into the reset button but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 30, 2009 | Creative Labs Zen MicroPhoto MP3 Player
My computer doesn't see my zen microphoto
Go to creative.com. There is a download place where you can get a new firmware. Your crative's firmware needs update. Read before you do something cause you might delete all your songs. I hope this wil help you cause it did the same thing to mine. Goodluck.
Jan 23, 2009 | Creative Labs Zen MicroPhoto MP3 Player
FM Radio was erased from the MP 3
OK this seems to easy a fix for you, but try it.
* In the main menu where it lists your options (and where FM Radio would be) press the 'Menu' button on your Microphoto (bottom right button) and there is an option to 'Configure Menu' and in there should be the option to show FM Radio again. Hope that helps you.
I have a similar, but different problem, so ill list below, maybe it will help someone out.
i also replaced the (broken) 8gb microdrive with 8gb compact flash in my Zen Microphoto, which worked flawlessly! BTW i bought the A-Data 'SPEEDY CF 8GB' from newegg.com.
My FM Radio still shows up, but only gets MONO sound on the Right channel, its very frustrating. i took it all apart again and made sure no connections were loose or broken, but everything seems perfect. i believe it to be a firmware issue, i think ill try to roll back the drivers. im using firmware 1.31.01.
its just annoying to have to roll back to Media Player 10 everytime just to install the firmware and have windows properly communicate with the zen... :[
Nov 20, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Re manual
You can request a manual; send me an email at TheGadgetDoctor@gmail.com. Header: "Request MicroPhoto Manual"
Aug 13, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Creative Zen MicroPhoto 8GB, in recovery mode, the device is not connected
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 27, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Creative zen micro photo 8gb not turning on.
remove the usb adaptor and remove the battery from the back.
and then put the battery back in and try it
or
http://forums.afterdawn.com/thread_view.cfm/307045
Feb 22, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Creative Labs Zen MicroPhoto (8GB) possible faulty USB Cable ????
When I had that problem on my Zen I un-installed all the software and rebooted my system and reloaded the software. Not sure why it worked but it did.
Nov 13, 2006 | Creative Labs Zen MicroPhoto MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
508 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
