Question about Canon MP830 All-In-One Printer
Paper will not load and cartridges won't come all the way out
When I go to print there is an error message saying there is no paper in cassette and there is. When I open to the top to put new cartridge in the cartridge tray does not come all the way out and blink as normal.
  • Anonymous Apr 14, 2009
    there is no paper load paper and press ok
    Problem Solver:
  • 7 Answers
Check which cassette you have it on. the lower one or the one in back.
Posted on Mar 10, 2009
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
Mar 07, 2014 | Canon PIXMA MG5320 All-in-One Printer
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
The paper jam indicator on in error?
So it sounds like the machine is not feeding paper from the paper cassette. This is a common problem.
There are 2 possibilities. 1 easy and one a little tougher. The simple fix is cleaning the paper feed tires. Just pull out the paper cassette, then remove all the paper. You will see 2 felt type pads on the spring loaded metal plate. Spray these 2 pads with some glass cleaner. Dry the metal plate a little then lock the plate down and re-install the cassette without paper! Make sure the lower tray is selected for paper feeding and press the print button. The machine should try to feed a few times then shut down with a P in the display. Reset the P using the clear key then press print again. Repeat this procedure 5 or 6 times. Then remove the tray, dry the pads a bit then re-load the paper, re-install the tray and give it a try. If dirty feed rollers were the cause then this procedure will fix it. Let me know how this works out.
Thank You for using Fixya
Apr 23, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
48 people viewed this question
old marine
old marine
