Vintage preamp pots and switches drop out and are noisey.
What is best way to clean the contacts in these without causing collateral damage? Which product is best for this purpose?
  • cpt_kaos Feb 26, 2009
    Thank you. I have done this once not realizing that I should repeat it several times.
  • 4,234 Answers
Look for an electronics switch cleaner spray that contains a lubricant. There are a number of brands out there. Any electronics parts supplier should have this. The key is that cleaning these will take a number of tries. Spray teh cleaner into the pots and swtiches and "work" them with the power off. That will work for a short time. Continue to work the controls and respray after a few days to clear out the stuff that the lubricant/cleaner will break down over time. It may take 3 or 4 times to completely loosen and clean out all the dirt etc that has accumulated over the years.
Dan
Posted on Feb 25, 2009
  • ABRsvcs Feb 26, 2009
    Please also realize that this may not work if the parts are too far gone. Also, don't just spray. You must turn all the controls and switch the switches many times over and over, Then let the unit sit for a day and do it again, The working of the controls will spread the lubricant and loosen up hte accumulated "crud". This is a common complaint. I probably see 2-5 of these a week.
    Dan
Left channel static
I have seen dirty switches or pots cause constant static. I would get some contact cleaner and try spraying it into all switches and pots, and work them to clean the contacts. Also, check to see if there is static in a low-level output such as the one for a tape recorder.
Mar 29, 2014 | Marantz Audio Players & Recorders
How to fix on a ninja crockpot e01
According to the manual it means the cooking pot is not inserted into the device.
Mar 19, 2013 | NINJA SEARious Slow Cooker
Thorn amplifier model 4044 volume control VR201 faulty.
put a few drops of "switch cleaning oil" inside the volume control by opening the cover & rotate the control a few times. you can use it on switches as well. you will see the control is working again. if that does not work, u need to replace the control pot.
Sep 26, 2011 | Audio Players & Recorders
Just got a vintage Onkyo receiver mod # TX-840. I have a very scratchy sound in both A and B right channels on all sources. Figured it was a blob channel HOWEVER this unit has a
Vintage hardware means vintage contacts on all the controls which means oxidation which would cause crackly sound or total silence. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts. Beyond that a trip to the hifi doctor would be advised.
Jun 21, 2011 | Onkyo Audio Players & Recorders
Need expert to rebuld wire harness for ibanez 2453,howard roberts . one of the pots is damaged.
Almost any guitar shop[ can replace a damaged pot without rebuilding the whole wiring harness. Pots usually only have three wires or some might have an extra pair if the pot has an integral switch. The hardest part will be to get an exact replacement pot.
Sep 27, 2009 | Ibanez AF75TDGIV AF Series Electric Guitar...
I have a problem with the Main Output on my Adcom 710 Preamp
Hi am gathering that when it is bypassed (tone) its fine which suggests that the problem is on the treble/bass pots or boards. Try cleaning all the pots with switch cleaner first (open the amp and spray it into the pots them selves through little holes). If not there then Check for a loose wire, and can also tap the boards with back of screwdriver while the amp is playing to listen for dry joints (loose solder and CAUTION for getting a shock also!!)
Pretty sure though on the pots or dry joints.
Best of luck
Jul 24, 2009 | Adcom GFP-710 2-Channel Amplifier
Without thinking I put frozen bratwurst into my Crockpot and turned it on high. Now there is a hairline crack in the ceramic insert. Can I safely repair this before the crock falls apart? What woold be...
I would suggest that by adding frozen goods to an ambient pot and the heater has kicked in causing a crack in the ceramic pot - this is unrepairable as the damage done is deep into the pot.
A similar problem is putting hot water onto a frozen windscreen - it will crack.
The damage is caused by applying alternate extremes of tempatrature to a solid.
You could glue it, but it may well leak later in use, or may not be entirely stable in the wash. You might find it could separate when you are cleaning it.
Sorry, but I hope this helps.
Oct 15, 2008 | Rival 37601 6-Quart
Volume control needed
have yoou tried to find in ebay.? they should have one there.
Jan 21, 2008 | Audio Players & Recorders
77 people viewed this question
 Grubhead
Grubhead
