Question about Panasonic KX-TG5100 Cordless Phone
Low volume on a dsl line
Very low volume on a dsl line
    New Friend:
    Problem Solver:
I'm sorry but what kind of answer is that? I came on here to find out where the volume control was. If people know where it was they would know to adjust it and would not be asking.
Posted on Dec 28, 2014
    President:
  • 1,952 Answers
Check the volume control then adjust high volume
Posted on Feb 25, 2009
Low volume on external forward calls
Are the phone company phone lines analog or POTs (Plain Old Telephone) lines? If yes, it is normal to have low volume when you put two analog trunks together. The fix is to use digital trunks from the telephone company like a PRI or T1 circuit.
You may really have low audio lines. Please see this link http://www.sandman.com/loopcur.html#CircuitLoss. Hope this helps.
Apr 06, 2013 | Mitel 5312 IP Phone
How to troubleshooting DSL conection
Hi.
look at your dsl L.E.D
if the lights blinking, meaning there is a problem on the DSL line and you need to contact the service line provider to solve your DSL line.
(Good
DSL line if the DSL L.E.D light is not blinking led (stable)
regards
Aug 04, 2011 | D-Link DSL-G604T Wireless Router
I have a second line for dial up and would like to switch over to dsl through my cable company to save some money can I drop my second line (dial up) and go to cable without any problems. I pay MSN direct...
DSL connection works on the same line provided by company who provides DSL. If dialup line is not provided by DSL company, you can drop dialup line and contact DSL company for DSL connection. If dialup line is provided by DSL company, migrate your internet plan from dialup to DSL by contacting DSL company.
May 30, 2010 | Computers & Internet
Speaker phone problem
It is possible. I have ATT 945(?) 4 line phones that communicate via a DSL-like signal between units to do special things like intercom, etc.
What I have in my setup is that I have a seperate line from the point of entry of my phone line to my DSL modem.
I then have TWO stacked DSL filters PER LINE that feed the main phone line running to all the phones.
Be AWARE that when using the speaker phone there is a modulation of the gains both directions. When you talk OR have a noisy background noise, the gain of the speaker is cut down to prevent feedback. And when you go silent, the speaker gain is increased for you to hear the other side of the call. Essentially it takes as much discipline as the old two-way radios... one talker at a time with these speaker phones AND very little background noise.
Jan 09, 2010 | RCA 25425RE1 Phone
Cordless phone has volume problems with DSL
For starters that dsl modem should not be filtered.
You should place the splitter directly into the wall jack and place the filter on the side used for the phone. The side feeding the dsl line should not be filtered.
The filter serves 2 purposes. 1 it reduces data noise interference onto the voice line. 2 it prevents dsl interference from voice such as picking up and hanging up the receiver.
Aug 26, 2009 | Uniden Cordless Phone
We cannot receive faxes in
First thing to look at, that is if you can send. Look and verify that the phone line is in the "line" jack and not the extension or phone jack.
Then be sure the fax settings are these. ECM is ON, Secure fax is OFF, Delay fax is OFF, and Junk Fax is OFF. Those 3 being set wrong will also cause that problem.
Another cause is a noisy phone line, or if the machine is on a digital phone line. Ex, DSL line.
Unlike sending, where you make an actual physical connestion, when you receive the line voltage and current have to be correct. So a phone line issue is possible. I relate it to haveing a tv remote with weak batteries. If they are low, there is not enough signal to chnage stations , volume etc. If the line signal to the fax machine ie weak, there is not enough signal to turn the fax receive on.
Start with the location of the cord, then the settings, the suspect the phone line. It is almost NEVER the machine, unless you experience a lightning strike.
Jul 10, 2009 | Xerox Phaser 6110 All-In-One Laser...
AT&T 974 corded phone
if your dsl is on the same line it will mess up micros for intercome system. Move dsl to another line
Jun 17, 2008 | AT&T ATT-974 Corded Phone
Wireless faxing
there's no such thing as wireless faxing, you need to connect the phone cable/line at the back of the printer where there is a slot there that says "line1" . faxes uses analog phone lines so you have to had a phone line. on dsl it may or may not work coz as ive said faxes uses analog lines which has low frequency while dsl has high frequency
Jun 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Volume changes on my Panasonic KX-TG5621
I've got the same problem with my phone KX-TG5621. I have no oher wireless devices in the house. I actually have returned this phone for another of the same model and it still does the same thing. I think it actually is the phone itself. These phones may not actually be as good as it seems. Does anyone else have these problems?
Jan 17, 2008 | Panasonic KX-TG5621 Phone
Telephone connection
what router is it its a voip router like vonage
Oct 17, 2007 | D-Link AirPlus DI-524 Wireless Router
Panasonic KX-TG5100 Cordless Phone Logo
712 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
