Question about Sharp LC-26DA5U 26 in. HD-Ready LCD Television
Hi, recently i just bought the Sharp Aquos lcd 32 inch HDMI tv.I try to connect my laptop ACER Aspire 4520 using VGA 15 pin cable.During connection,My laptop became hang or jammed and my lcd tv just came out " the signal is not compatible ".What should I do to make my tv connect to my laptop works.Can you help me to solve it? Thanks Adzree
SOURCE: Clean screen
I used the Monster "Screenclean" kit, which left a film on my screen. I am not happy with it. Any suggestions on a different product which will remove the film?
Posted on Jun 06, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • 86 Answers
SOURCE: signal is not compatible with this input when i connect my laptop
If the screen resolution on your laptop is to high or not supported by the TV, that is the usual error message.  I'm not sure what video output you are using but if it's the common S-video output, high resolutions will not be supported through it so maybe try a lower resolution and work your way up until you get the message again.  Then you will know the threshold.
Posted on Mar 26, 2009
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Picture too big for screen
on the remote press menu, use the up and down arrow buttons to seach for aspect/screen press select/enter to choose the screen (you probally have it on zoom)
Posted on May 06, 2009
I can't get my laptop to work on my tv
Is your graphics card compatible with your model of tv? or have you purchased the correct lead for it?
Aug 01, 2012 | Acer Aspire 7520-5185 Laptop
How do I connect my Acer Aspire 5742 to Sharp Aquos LCD TV
Which operating system? I know in XP I've had to set up a dual monitor screen before the OS will broadcast to the VGA/HDMI port.
Dec 31, 2011 | Acer Aspire 5742Z6682 Notebook
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
Hi Guy's I have an Acer Aspire 5315 laptop and a 32" Bush flatscreen TV. What cable do I need to connect the 2 to watch movies etc Cheers
Use a 15-pin, male-to-male VGA cable to connect your laptop to your TV. male-to-male means the pins are sticking out on both ends. Since both ends are male, you'll need to find the female VGA input on your laptop and on your TV. This is often called the PC input. Now, connect one end into the TV and one end into the PC. On a Mac, the VGA input is conveniently labeled with a "display" icon. It's recommended that you do this with everything powered off.
Sep 27, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How to use a sharp aquos as a monitor with my laptop
Hi. You haven't said how you have connected your laptop to your TV so I'll give you a couple of options:
1. VGA to VGA (This cable is a 15-pin cable like the one you would use to connect a computer monitor to the back of the computer box itself). The Sharp has a VGA connection at the back.
2. DVI to HDMI. If your computer has a DVI output, this would be the best connection.
On your remote, press menu.
Use the left/right arrows to select option
Then use the arrow up and down to select input source.
Depending on the TV you have, you will either see the actual name of the connection (ie. HDMI, DVI, VGA) or you may need to select Input 1, Input 2, etc... depending on which connection you used. The input number may be labelled on the back of your TV.
If none of this works, please let me know your model numbers and I can provide you with instructions specific to your models.
Jan 19, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-26DA5U 26 in. HD-Ready LCD Television Logo
77 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
