Network cable stopped being recognized
I've used this computer with a cat5 connection to the router for years.  The other day it just stopped recognizing the connection and says "a network cable is unplugged"  Other computers get internet just fine from the same cable. i have the same problem i tried re-instaling drivers, everything, the connection light doesn't even come on, the only thing i can think of is i just install ATI Catalyst Control Center, maybe somehow the drivers changed something i don't know. Device manager says the card is working fine. I really need help
  • 1 more comment
  • Palinkas Feb 26, 2009
    Ya i would do that but i've used up all available PCI slots, and it seemed like as soon as i got my graphics card working properly i lost internet. i downloaded catalyst control center, installed it restarted then bam, network cable unplugged, light don't even come on. I thought it could be a IRQ conflict, but it doesn't seem to be i have a couple doubles but not on the ethernet card, and no conflicts are registered
  • Palinkas Feb 27, 2009
    the motherboard is a Asus P4S800-MX and the graphics card uses a AGP slot and is a ASUS AH3450 which uses a ATI RADEON HD3450 GPU Also if its any help the onboard Network card is a SIS 900-Based PCI Fast Ethernet Adapter
    Thanks For your time i really appreciate it, this is driving me nuts!
    yes it is a new graphics card, i installed CCC when i installed the card it came with the driver install file from asus. this is a computer i just use on my flat screen to play movies and such added a bluray drive to the computer and a 5.1 sound card i needed to add a card to have SATA to connect the bluray drive, I actually have one more pci slot but can't fit anything in it because of where i connect the power supply to the video card hangs to far low and blocks the space. this is really frusterating me i might just get a USB wireless stick but hard wire is much faster and i'd really like to use it. Do you think there is any hope
  • 203 Answers
Ati catalyst is for a graphics card.
it would not have issues.
the card may show as fine, or the drivers may. try the card in another pc. if it is built in try a new card. ethernet cards are just a few pounds.
Posted on Feb 25, 2009
  • 1 more comment
  • sean sutton
    sean sutton Feb 26, 2009
    what motherboard are you using?
    also what graphics card are you using?
    i'll ask a few pals and see what they think.
    i'm sure we can get to the bottom of this.
  • sean sutton
    sean sutton Feb 27, 2009
    i have that same motherboard sitting on my workshop floor for kicking around when i am pissed off.
    it failed on me a month or so ago and getting anything from asus is a pain. thier tech support is rubbish.
    i'm not suggesting you do this with your motherboard, it wont help.lol
    is it a new graphics card?
    did you install ati when you installed the card?
    what power supply are you using?
  • sean sutton
    i have a wireless dongle on my sons pc and it works at 52mbs so just over half the speed of a cable which runs at 100.
    i personally use a 108mbs wireless from d-link which needs the 108mbs hub too. but that uses a pci slot. i think the best you could get is 54 from a usb.
    you should not have conflicts between your card and motherboard really?
    i also dont see why catalyst is being a *****?
    you could try rolling back the drivers for your ethernet connection through device manager incase ati driver altered it in some way. also i have found before that windows update can mess up device drivers by telling you that you need a new one when you actually dont.
    if you need help with doing this let me know and i will help you with that.
Hello friends How can I set up my computer win7 to the Konica minulta printer by network cable cat5 please answer very detail.Many thanks.
First, you CAN'T connect a CAT5 cable directly from your PC to the Printer. That won't work. Both have to be connected with their own CAT5 cables through a hub or router on your network. The router gives them separate IP (network) addresses so they can talk to each other.
You may need to set up the printer through a direct USB connection to your computer. Once the networking options are set, IF it's an Ethernet-capable printer you may be able to connect that way.
Jan 20, 2018 | Konica Minolta Office Equipment & Supplies
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My internal wireless adapters will not connect to WPN284 wireless
Make sure the default gateways and DNS servers options for both wifis point to your wifi router
Mar 30, 2009 | NetGear RangeMax WPN824 Router
How do i hook up a router
Let's proceed first with the physical connectivity. Please follow the steps below:
1. Make sure that your computer is working when directly connected to the modem.
2. Connect the CAT5 cable of your modem to the WAN port of your GWA504.
3. You should have another CAT5 cable. That CAT5 cable will be connected to any one of the LAN ports on the back of that router.
4. Connect the other end of the CAT5 cable to the network card of your computer.
5. After the physical connection, just let me know and we will proceed with the next steps. Because your statement is very broad. We have to consider lots of things here. Please reply so that I could further assist you.
Mar 27, 2009 | IOGear GWA504 Router
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
