Question about Xerox WorkCentre M15i Laser Printer
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
ANOTHER PROBLEM WITH THE SAME XEROX WORKCENTER M15 IS THAT THE SCANNER LIGHT IS ALWAYS ON AS LONG AS THE ON/OFF SWITCH STAYS TURNED ON. I ACQUIRED THIS USED, SO I DON'T KNOW IF THIS IS NORMAL.
    President:
  • 2,072 Answers
That is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Posted on Feb 28, 2009
Is stuck in scanner mode
did you check the scanner cable and the optics or the harness or a program, or a sensor or scanner board the harness cable maybe misallign
Feb 19, 2013 | Xerox WorkCenter M15i
My all in one printer xerox workcenter 3220 gives me a mssege (Scanner Locked) do you have any answer please?
Scanner lock is located underneath the scan assembly, where the paper exits the printer. It may be stuck so slide it back and forth a couple of times.Unlock the scanner and then press 'Stop/Clear'.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
Our xerox workcenter m15 had a paper jam. we turned the power off, fixed the jam, and turned it back on ... but no power now. We unplugged everything, replugged and tried again - no power.
The simplest solutions:
Plug a small apliance or light Into the wll otlet to determine if there is power in the outlet
If the appliance does not power ON, the problem is in the power outlet. Contact your building maintenance department to check the breaker in the electrcal panel.
If there is power check that the power cord is securely plugged in to both the wall socket and in to the machine.
Turn off the power switch on the left-hand side of the machine; wait one minute; turn back on.
If these steps do not resolve the problem you may need to contact a service representative.
Dec 08, 2010 | Xerox WorkCentre M15i Laser Printer
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
Our workcenter m15i has a OPEN HEAT ERROR ?
Best thing to do it replace the fuser.
You can google a business called "the parts drop". Call and ask for Britt, He will have the parts you need at a fair price. I dont work there, but have done business with them for long time.
He may also just recommend some parts to replace.
But if the fuser has over 30,000 prints on it, it really is worth just putting in a new one.
Its easy to reaplace. Just 4 small screws.
You may want to first off, open the right side door, as if clearing a jam. One the upper rear, there is a white connector from the fuser to the frame. It may have become unplugged if the plastic cover is missing.
Jun 17, 2009 | Xerox WorkCentre M15 All-In-One Laser...
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
CANNOT GET INTO THE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
Once you press menu #1934 you have to then press the machine status button then scroll to maintenance, then scroll to clear memory. Once you do that repeat entering the tech mode, press machine status, maintenance and perform a shading adjustment with 5 pieces of paper on the glass, that will recalibrate the scanner.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCentre M15i Laser Printer Logo
205 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
