Question about Panasonic PT-LB10SVU Multimedia Projector
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
I just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
I just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flashPanasonic PT-LB10SVU green light flashing,then ora - 2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes orange...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Takes to long for unit to come on, when pressing power on remote, green light comes on, but it takes over an hour for the picture to come on.
could be a lamp problem, turn the set off, watch the front led light next to LAMP, count how many flashes in sequence, eg. 2 flashes indicate lamp problem, 3 flashes internal overheat problem. if a orange light flashes next to POWER indicator you have a power malfunction.
Aug 22, 2010 | Panasonic PT-61LCZ70 Television
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Lamp wont light. Green then Red on power. Orange
    hello The lamp cover is ajar. Firmly replace the cover
    shaun
    Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT L501u Replacement Lamp
    panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
    so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
    thats all the unit powers off & when u check the lamp counter , its shows 0
    u r done!!!!!!
    Jan 22, 2009 | Panasonic PT L501U Multimedia Projector
    Panasonic PT 50LC14 problem
    You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
    Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
    Panasonic PT-LB10SVU Multimedia Projector Logo
    2,536 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
