Question about Nintendo NES Console
Only the Start and Select buttons don't work on my Nes Controller
The controller used to work, but now I can select up and down, and use the a and b buttons, but start and select don't work.
    Novelist:
  • 149 Answers
Take the controller apart and check the wire connections on the controller card. There are many times with a system this old that the wires could be pulled off the board. If the wires are disconnected then you may have to solder them back together. If they look good and are making good contact then check the area where the start and select buttons are. You may need to just clean the area. Use alchol and a small soft bristle brush or a Q-Tip and clean the area and allow it to dry. This should get the buttons to work again.
Posted on Feb 26, 2009
No audio video
NES AV to TV Hookup
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2012 | Nintendo NES Console
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Sep 17, 2007 | Nintendo NES Console
How do i sync my DreamGear PS3 Radium Wireless Controller - DGPS3-1394
How do get the start and select button to work when I plug the USB in and turn both the controller and ps3 on I load in a game and can't pause my game or change views
Dec 06, 2011 | Video Game Consoles & Games
I got a NES (finally) but i got a problem. when i start it up with (for example) zelda i can select a save, in other words when I push the up or the down button it does nothing. But when i press start to...
The reason it doesn't work in the menu is because it doesn't use the D-pad (the plus-shaped button that you use to move around). To go through the menu options, you need to press the Select button (that's the left of the two small buttons in the center of the controller). Many games use that to select menu options instead of the D-pad.
Jul 06, 2011 | Nintendo NES Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Installation Steps:
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
How do you use an advantage controller
The Nes Advantage is one of those weird controllers. It is set up to function as a dual controller.. Kind of.
You have two plugs for player 1 and player 2 on the controller (If you are wanting to just use it for a 1 player game only one has to be plugged in - Not sure on the layout because both plugs are not labeled).
There is a player select button on the controller that can be set to first or second player. Set it to 1 and enjoy the stick.
If it is not responding you will have to switch the plug to the other.
Feb 14, 2010 | Nintendo Video Game Consoles & Games
NES controllers won't work!
Using the select button will switch between the options.
Jun 17, 2009 | Nintendo NES Console
Nintendo NES Controller Problem
try going to an old school game store and see if they have and nes controller then try
Mar 10, 2008 | Nintendo NES Console
Super Nintendo Start/Select Button not working all the sudden
your problem will be with the mating surfaces of the switch contacts themselves.
i,ve cleaned several console hand-pads. to find that sweat and food debris mixed together, get under the contact pads.
this is the small piece of carbon ( mounted under the silicone rubber pad ) inside the controller.
these should be wiped with a cotton bud, swabbed in a small amount of lighter fluid ( or methylated spirits ) and wiped clean.
re-assemble controller.
check the cable for signs of wear, also the controller port mating surfaces should be shiny copper connections. if these are not mating with the controller, then no signal is being transmitted between the pad and input ports.
look carefully, if any pins are lower than others, take a fine electrical screwdriver or needle, and gently bend the pin upwards, so that they all align at the same height.
Failing this, you have faults on you controller port input sockets.
these can be replaced, as they,re ribbon cabled to the mainboard. this is a job if your electrically competant.
Hope this helps.
Mike @ Compurepair.
p.s if it was simple, everyone would be doing it :)
Feb 23, 2008 | Nintendo Super NES Console
Snes controller
It is common for buttons on any video game controller to quit working and it is usually an easy fix.
Assuming the cord is in good condition the problem is internal. Turn the controller over with the buttons down and remove all of the screws on the back. Carefully lift off the back. You are now looking at the back of the circuit board. Look closely at how the cord is routed through the plastic pins as you will have to put it back in the same location. Remove the cord from the pins and carefully lift out the circuit board. Turn the circuit board over and locate the contacts for the buttons. There are four on the left side for the D-Pad, two in the middle for the Select/Start, and four on the right for the A,B,X, & Y. These contacts need to be cleaned. A hard eraser works best. Reassemble everything and it should work fine for quite some time.
Jan 19, 2008 | Nintendo Super NES Console
Nintendo NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
