Question about Viper Vehicle Parts & Accessories
Alarm System I have a Viper 350HV alarm system and i disconnected my battery and i was wondering if that would reset my alarm system?
No it won't reset your alarm system. As part of the bit-writer program, anything you set or change in the alarm menu will remain the same. The only thing that can happen is if you have a DEI 520t back up battery, it may trigger the alarm upon re-connecting. No biggy.
Posted on Feb 28, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
Mar 04, 2013 | 350 HV ESP Security System 350HV ESP
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Car alarm doesn't go off with light impact
bumping or rocking the vehicle is not an impact .
Oct 04, 2017 | 350 HV ESP Security System 350HV ESP
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but...
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
My 350hv just shuts off randomly. I can arm it and come back later and it is off and my doors are unlocked!
Sorry, but it is my opinion that car alarms are really, really foolish.
Cars are extremely hostile environments for delicate electronics.
Adding alarms is begging for problems that will leave you without a car.
If you lock any valuables in the trunk, out of sight, there is no reason for an alarm. All an alarm will do is either fail and prevent you from driving, or fail and get you a ticket for a false alarm.
Jun 20, 2010 | 350 HV ESP Security System 350HV ESP
Problem just started sunday...when the alarm is armed it would show the locked sign on the remote....now it doesnt show that its locked and beeps like its not getting signal...but the car did lock with the...
I have the same problem. The easiest way around it is to disconnect the battery for 10 seconds and reconnect it. This will reset the alarm system, and the remotes will start working again.
Take note of your radio stations as they will reset. :)
Dec 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
350hv did not come with a installation manual I I
their award-winning (Aernt they all?) Technical Support department can be reached toll-free at 1-800-753-0600, the guide is here on pdf - http://www.directeddealers.com/manuals/og/viper/G426V_07-05.pdf
but installation info is sketchy. Hope it works out well, great alarm system.
Jun 28, 2009 | 2001 Toyota Tundra
Van won't start after thunderstorm set off viper alarm system
Not saying this is your solution. I would do the simple thing first. Disconnect the battery for 5 to 10 minutes and see if it allows the alarm to reset. If not call your local car alarm installer. Maybe Best Buy. These companies will more than likely help you out
Apr 19, 2009 | 1995 Chevrolet G20
Vehicle Parts & Accessories Logo
622 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
